Old 07-14-2013, 07:25 PM   #11
Denver, CO
garbonz's Avatar
You both are making the assumption that he doesn't have like minded neighbors (if any, at all)...
X2. you are amking assumptions that just on't fit here. Cut it out, and help da OP
2017 Fuse 23T
Old 07-14-2013, 07:50 PM   #12
Rolling buckeye's Avatar
IMO sounds like you are using the factory wiring, it may be too small,,as the amp draws on this wiring, it may not be getting the current it needs, due to the wire size,and resetting to protect it self. Point, I think if you replace the converter, and still use the small gauge wire, you may not fix this problem. Also, if you are running any other things at the same time, that will multiply the problem,this is why it is suggested to run directly to battery, with a fused link. But , you will have a better system !
Rolling buckeye is offline   Reply With Quote
