Old 06-09-2015, 12:29 PM   #1
The Wayfarers
Palletbob's Avatar
Cool cat and Furnace run together
My wife went to change to furnace and touched the cool cat instead we think. Now when we turn the furnace on, both come on together now. We also changed it from F to /C but found out how to turn back to Fahrenheit. But how do we stop the cool cat from running at the same time short of pulling a fuse to cool cat when we want to run the furnace?
Also, Does anyone know if there is a fan inside the converter? I thought I heard it once but now haven't heard it. Maybe there isn't one.
2013 Chevy 1500 Silverado
2012 A 128 S 2020 178 RPod
Days camped 2015:98 Az, Chi,Mn,N.D.,Mt,Id! Wa, Or,Ca
2016 camped 118 Az,Chi,In,Mi,Oh,Ny,Vt,NH,M
2017 camped 88 az,Chi,Mo,Ok,Nm,Co,
2018 Ok, Ks, Ia,Mn, Ill,Wi, Mi, In, Mo, Ak,Tx & N.M.f
Palletbob is offline   Reply With Quote
Old 06-09-2015, 04:20 PM   #2
On ours if I select fan on the electronic thermostat then change the mode from auto to low or high it causes the fan on the ac to come on when the heat is turned on.
To fix it, select fan on the thermostat and set it back to auto. Then turn the unit off. Then turn the heat back on and only the heat will come on.
Hope this helps
2015 Forest River Grey Wolf..Traded
2015 Forest River Cherokee 274RK
2001 2500hd...garaged
2015 Rubicon 2d and 2015 Jeep SRT
Simplewon is offline   Reply With Quote
Old 06-09-2015, 04:24 PM   #3
wmtire's Avatar
Hope this helps
X2 on the "auto" setting as Simplewon stated above. This is a common situation and question with the digital thermostats in various RV's. It happens a lot.
Furnace Operation
2011 Flagstaff 831 RLBSS
Never Apologize! Never Explain!
Sorry, thatís my motto.
Old 06-10-2015, 05:09 AM   #4
jmh
Happened to 3weeks ago. Just did what simplewon said and works fine now
jmh is offline   Reply With Quote
Old 06-10-2015, 11:56 PM   #5
Yes there is a cooling fan in the converter. It only runs as needed and at veriable speed in most models.
walljammer is offline   Reply With Quote
cat, furnace
