Moving the thermistor down on the fin makes the refrigerator warmer.
Moving it up, makes the refrigerator colder.
Look for a sticker about thermistor adjustment.
I have a Dometic and keep the thermistor at the top of the far right fin. When the outside temps are above 80, it tends to go above 40.
If the thermistor is taken off the fin, it will run the cooling system longer and get the fridge colder. Put it back on before the fridge gets too cold.
Get a remote thermometer (Walmart has them) and you can monitor the temps without opening the door and letting the precious cold air out.
Food safety: less than 40 or higher than 140.
Chris and Pat
2016 Ram 3500 Cummins Aisin Dually, 4.10 axle, Auto Flex Air Ride Rear Suspension, Pace Edwards JackRabbit tonno, Transfer Flow aux fuel tank, B&W RVK3600 hitch
2017 Cedar Creek 36CKTS, Disc Brakes, 17.5"
