Old 06-21-2015, 09:00 AM   #1
tjcreed's Avatar
counter tops replacement
Good day to all, I have a pop-up Flagstaff and the counter top over top the furnace has at some point gotten wet and the edges have swelled resulting in the edge molding coming off.
As i have purchased this unit used I don't have the edge molding. The question is I can't find a supplier that offers the edge molding in crescent or bullnose that is only 3/4 in. Find all kinds of larger edges. would really like to keep the interior matching. Top design is of Jeweled Coral. Only need a small 2 ft. square piece with edge molding at right angle on 2 sides.
Can anyone offer any help? thanks
tjcreed is offline   Reply With Quote
Old 06-21-2015, 04:43 PM   #2
You may be able to glue on the wider edging with the extra on the bottom ---- even with the counter on the top and then use a trim router to remove the extra on the bottom.
bruceatlam is offline   Reply With Quote
Old 06-21-2015, 04:54 PM   #3
Or add a backer board for the wider trim and make the counter top look thicker.
replacement
