Old 10-12-2015, 04:00 PM   #1
Crusader 370BHQ 2nd A/C Not Cooling
We've gone several places since we purchased our unit in July 2015. The problem we're having is the 2nd a/c in the bunkhouse is not cooling properly. We have to leave the door from the living area open and run a fan so cool air will be pulled from the living area. Any help will be greatly appreciated.
ib4au2 is offline   Reply With Quote
Old 10-15-2015, 06:56 PM   #2
BDavis's Avatar
What model AC? There are a lot of posts about defective Brisk Air II models. I have a new 365 saqb that doesn't cool.
2016 Sandpiper 365asqb
2013 Rockwood Windjammer 3006W
2014 F250 6.7 PowerStroke 2wd
BDavis is offline   Reply With Quote
Old 10-16-2015, 09:25 AM   #3
It's a dometic 15000.There are only two vents in the rear bunk house with no air return.
Old 10-16-2015, 12:10 PM   #4
BDavis's Avatar
They are having an issue with the Brick Air II 15k units. There is a service bulletin floating around. Let me see if I can find it. Regardless it is under warranty in your dealer will take care of it. That is assuming that the unit is less than 2 years old. It has affected the Dometic units manufactured between 2013 and 2015
Old 10-18-2015, 10:30 AM   #5
BDavis's Avatar
Check your ducts for blockage as well. Mine had tape still covering the vent holes.
cooling, crusader
