Old 11-21-2015, 02:47 PM   #1
Dash lighter-outlet not working
We have a Georgetown 364TS, purchased new in the spring. We plugged a splitter into the dash cigarette-lighter-outlet to power the GPS and a phone charger. It worked great.
Then it stopped working. No power.
I just checked every fuse in the fuse box under the steering column, as well as every fuse in the master bedroom. They are all good.
What else should I check? What else could it be?
Dweeks is offline   Reply With Quote
Old 11-22-2015, 04:04 PM   #2
Kenny kustom's Avatar
Anything else not work?
2015 RAM 3500 CCSB CUMMINS
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 11-22-2015, 04:21 PM   #3
Ford Idaho's Avatar
Check the engine compartment for a black fuse box.
Old 11-22-2015, 04:59 PM   #4
Usually tied to radio, dome, or like fuse( if wired constant)
2016 Sabre 36QBOK
Old 11-22-2015, 06:02 PM   #5
Mr. Dan's Avatar
It's listed as "Cig lighter" or some such in some vehicles.
Old 11-23-2015, 12:50 PM   #6
Are there fuses in the driver's side front storage bay. On my Legacy the fuse was labeled 'Power point' - 20A.
wintertexan is offline   Reply With Quote
Old 11-23-2015, 05:03 PM   #7
BobHanke's Avatar
Can you power just the GPS in that power socket? If you can, then check the splitter to see if it has a fuse in its tip.
"Lurch" = Georgetown 2011 330TS
Toad = Jeep 2016 Cherokee
Pilot = Bob
First Mate = Xiangbing
Crew = Radar, NiuNiu & NaNa
BobHanke is offline   Reply With Quote
Old 11-23-2015, 05:05 PM   #8
A lot of the plugs that go into the lighter socket have a fuse built into the end under the spring loaded pin. You can unscrew the end to access it. Not sure from your post but it might be your issue.
RandyLee is offline   Reply With Quote
Old 11-23-2015, 07:40 PM   #9
ArmyProud, Retired
I have a Forest River FR3. The fuse for 12V sockets (cigarette lighters) is in-line, under the dash just behind the socket.
glwolf is offline   Reply With Quote
light, electrical
