Old 10-19-2013, 10:12 AM   #1
MPI_Mallard's Avatar
Daydreamer furnace wont ignite
Right, fall has arrived and it's time to migrate south but not quite yet so I hit the swich to fire up the furnace to take the chill out and all I get is fan, no heat. Any suggestions??
07' Dodge 3500 Diesel Dually/6.7L Bully-Chipped / 68RFE six-speed/Jake Brake
07' Cedar Creek 37CDTSD Daydreamer fiver'
Mallard @ Frau Blücher
MPI_Mallard is offline   Reply With Quote
Old 10-19-2013, 10:33 AM   #2
Ford Idaho's Avatar
Ummmm!
Punt?
Circuit breaker.
Fuse.
Enough power?
Old 10-19-2013, 10:33 AM   #3
The obvious: do your stove burners burn ok indicating sufficient propane?
Is the fan air coming out if the furnace ducts or the AC ducts?
Old 10-19-2013, 11:04 AM   #4
yup! Both tanks are full, stove/water heater runs fine, air's a'blowin' out the floor vents. I tried cycling the furnace several times but lo luck, the dumb thig was working fine last week but,,,
Old 10-19-2013, 11:14 AM   #5
There are several furnace documents in our Library (link in the green bar in the top part of the screen). You might start with this one: Suburban Furnace Troubleshooting Guide.
There's also a "how it works" document.
Old 10-20-2013, 10:41 AM   #6
Thanks Barry,handy PDF!
Old 10-20-2013, 07:23 PM   #7
I found a golf ball sized hornets nest at the rear of the intake tube,i removed it and the furnace fired and ran for 30 seconds then shut off, due to the way that CC installed the unit BEHIND the sidewall under the fridge the only access is from the garbage door ion the right of the unit, aside from removing the whole fridge cabinet I can't see how I can remove the unit and get to the squirrel cage for further inspection, what the hell were CC thinking by not having the front of the heater where ALL the service is done mounted through the wall??
furnace
