Old 05-17-2018, 03:26 PM   #1
Question Dead Circuit
Hi,
I have a 2017 Rockwood 2109S with a dead 12V circuit that controls the interior ceiling lights, porch lights, and awning. A month ago the fuse blew (indicated by red light in panel). Replaced 15 amp fuse and all worked fine. This week circuit is dead again, but fuse is fine. Loose ground? Where do all the leads come together? Where is the ground? Is there a wiring diagram available? Help! Where do I start?
2017 Rockwood 2109S
2017 Jeep Grand Cherokee "Hemi"
jrl95608 is offline   Reply With Quote
Old 05-17-2018, 03:36 PM   #2
Thurman's Avatar
Are you checking the fuse by looking at it to see if the fusible link had broken or are you using a multi-meter to check the fuse out of the fuse box? Sometimes those 12vDC fuses will look good but really are not. Are there any other 12vDC circuits in you unit that are working good? IF so that would indicate that the fuse just behind the battery box (on a lot of units), usually under the RV is not blown. IF you have another/other 12vDC circuits that do not work I would certainly find and check that 12vDC fuse up front.
Thurman is offline   Reply With Quote
Old 05-17-2018, 06:20 PM   #3
Smile
I replaced the fuse with a fuse from a working circuit just to be sure. Other circuits working O.K.
2017 Rockwood 2109S
Old 05-17-2018, 06:28 PM   #4
Flybob's Avatar
If the fuse blew, there was most likely a short. Have you made any changes to the RV ( screws in a wall etc). I don't believe it is a ground issue, sounds like the power side is shorting to ground somewhere along the path.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-17-2018, 06:59 PM   #5
Question
Thanks for your service! You are probably correct. We just replaced the front "a frame" jack. I also talked to the dealer service dept. and he said a common problem was a pinched line, maybe on the rolling awning frame. Now I have to figure out how to unroll the awning with no power!
2017 Rockwood 2109S
Old 05-17-2018, 07:44 PM   #6
Brother Les's Avatar
this might help
Brother Les
Old 05-23-2018, 11:54 AM   #7
Local repair shop found a break in a line from the fuse box to the Trailer Control Panel. Unfortunately the break is somewhere underneath and hidden by the insullation padding, so the tech ran a new line from the last visible "hot" spot to the Control Panel. Who knows what caused the break? Rodent, other? Anyway, after diagnosis and rewire time, it was a $350 fix!
2017 Rockwood 2109S
