Old 07-30-2011, 10:10 PM   #1
locknload's Avatar
Dead Concertone
We have a 2010 831RKSS. We arrived at camp Wednesday and when I went to power up the Concertone for music, nothing happened. The power light is red but is unresponsive. It's worked in the past. Fuses appear to be ok, any ideas? Thanks.
2010 Flagstaff 831RKSS.
2000 Excursion Limited PowerStroke Diesel- ATS ported housing, Riffraff's FRx, HPx & I/C boot kit, DiPricol Optix- Pyro/Boost/Trans, DP Tuner-80t, Drive-Thru, 80e, 120race, K&N intake tube w/6637, Exhaust, AIH delete, Foil delete, 4" lift, Airbags, Dunlop Rover M/TMaxx 315/75/16's, '04 headlights.
locknload is offline   Reply With Quote
Old 07-31-2011, 06:15 AM   #2
Check the connections on the back. The concertone has a set of short wires from the back of the unit. The installer then hooks the power/ and apeaker wires to that. I have seen very poor use of crimp type connectors at this point. The wires will probably just be hanging in the space behind the concertone. The slack in the wires should really be wire tied in something that is going to be moving and bouncing. Let us know.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 07-31-2011, 03:04 PM   #3
good point KBROWN1075: ON my X75 concertone I was able to see the back connections from a removed drawer. And what a mess of wires all hanging down and not even attached. One day I will have to secure all this spagetti city inside the wall.
capucine is offline   Reply With Quote
Old 07-31-2011, 03:49 PM   #4
pull the fuse and put it back in this will reboot your concertone
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 08-01-2011, 04:26 PM   #5
locknload's Avatar
Thanks, I'll check out the wires.
Chevy, is the fuse an inline behind the unit or are you talking about the main fuse?
Old 08-01-2011, 06:14 PM   #6
Redheaded blue tick's Avatar
locknload, we went thru 3 of those units in three months, the third being the new genisis unit that is working great. we changed them out ourselves and found a rats nest of wires, its not that bad to straighten out, a lot of it fell down behind the t.v. there is an inline fuse, at least there was on ours. one thing we did and it helped alot with the poor reception was to pull the antenna wire out of the mess of wires and coil it up and tie close to the roof under the antenna. good luck.
Pat and Angela Malerk
2017 Dodge 3500 Diesel Dually 4x4 towing
2011 Rockwood Windjammer 3008W
Hitch: 1200 Equalizer
Redheaded blue tick is offline   Reply With Quote
Old 08-01-2011, 07:44 PM   #7
locknload's Avatar
Thanks Pat.
Would the power button still illuminate red if the fuse was bad? I should be able to take a closer look tomorrow after work or Wednesday.
Old 08-01-2011, 08:27 PM   #8
Triguy's Avatar
Locknload,
I have the same symptoms with my Genesis 2.0 - power button is red but unresponsive (although the remote will work the radio). My fuses are fine. I took it into the dealer and they couldn't get it to work either or figure out a reason why. They're ordering me a new radio (under warranty in my case).
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-01-2011, 11:15 PM   #9
Lock if you pull the fuse in the main fuse box and reinstall it this should do the trick has always worked for me
Old 08-02-2011, 09:12 PM   #10
Dodge Guy's Avatar
The simplest thing to do if the fuse is good and it will not reset is to replace the Concertone with an old AM tube radio! you may have to wait for the tube to warm up but it WILL work! seriously I replaced mine with a JVC headunit designed for a car. much better sound and the surround still works along with the sub in thr ceiling. and I still have the outside speakers working.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
