06-22-2018, 09:35 AM
Dead Short
We just took our 5th. wheel out for the third time this year, (last being 1 month ago) when we connected our 30 amp power cable to the power feed outlet on the post, it would trip the 30 amp circuit breaker in the power feed box (on the post) immediately. Even after resetting the breaker every attempt resulted the same, tripped circuit breaker. When I plugged just the power cord to the outlet, (not connected to the RV), the breaker didn't trip. Just to be sure, I ohmed out the cord, it tests good. The batteries and the 12 volt system test/work fine. Any thoughts ?
06-22-2018, 09:51 AM
Plug in the cord with no trailer. Check voltage. Hot to neutral 120 volt. Hot to ground 120 volt. Neutral to ground no volt.
Check the pedestal. Unplug the cord. Right side slanted slot is neutral. Check it to ground. no volt. Hot is left slot. check to ground 120 volts. hot to neutral 120 volts. This is why you need an EMS.
If all this checks out the problem is in your trailer.
By "OMHED OUT" I'm assuming you checked black to black end to end. White to white end to end. Green to green end to end and got continuity on all three?
Try turning a few breakers off in the RV. If you have several high use items set turned on, the combined startup current could be greater than 30A. You could also have a bad breaker as they take quite a bit of abuse.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
06-22-2018, 09:55 AM
Turn pedestal breaker off
Hook up power cord like normal (both ends)
Turn off all breakers inside rv
Turn on pedestal breaker
(If it trips again, the converter/distribution panel is the place to start looking for problems.)
If it does not trip then go inside rv and turn on breakers one at a time to see which circuit is the culprit
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
06-22-2018, 11:17 AM
Dead Short
Sorry, I didn't mention that I tried it at 2 other sites with 30 amp service on the "pedestal" with the same result. I also tried it with the breakers inside the RV turned off, same result. How do I test the converter/fuse panel ? I'm no longer in the campground, nor do I have access to a 30 amp service. I do have a multimeter.
06-22-2018, 11:39 AM
Good additional info. It is possible that one of the wires on the connector on the side of the RV has come loose and caused a short. With the unit unplugged, you will need to check the back of the power plug on the side of the RV
TST Tire Monitors
2 100W solar panels
06-22-2018, 11:48 AM
^^This^^
We've had several reports here of the wire connections coming loose/shorting on the back side of the shore power connection on the side of the R/V.
You are going to need to access that AND trace and check the wiring from there to the distribution panel/converter before condemning the distribution panel/converter.
06-22-2018, 11:50 AM
You've checked the cord but have you checked the receptacle it plugs into on your trailer?
Mine has a tendency to fill with water and you could have a shorted out receptacle. If you have all breakers inside the unit turned off and it still trips the breaker on the pedestal when you plug in, the converter isn't part of the equation. It should be turned off and that would leave only the wiring to the power distribution 12ov bus inside the converter enclosure.
I'd also check the back side of the power inlet receptacle for signs of shorting.
A relatively quick series of checks that would isolate your problem"
Plug in cord while not connected to trailer which I believe you've done. If it doesn't trip, then plug in, If it trips, go to the power distribution panel in the converter housing and disconnect the Black (hot) wire from the 120V buss. Put a wire nut on it for safety and then go back and reset breaker. If it remains on, you problem is in the 120 v buss that all the breakers plug into. If it trips you have a short between power distribution buss and the receptacle. My guess is the receptacle as it's been exposed to weather.
Work your way up the stream without just jumping back and forth.
