Old 01-11-2014, 11:39 AM   #31
TxTravelingRN's Avatar
Originally Posted by cmptrkd View Post
Might want to check up by the battery, my buddy's Surveyer by Forest River has electric stabilizer jacks and he has a fuse right there at the terminal for each front and rear set of jacks. I hope you find it, and it's something simple.
I think I found what you're referring to (see attached photo). Would be odd for both fuses to blow simultaneously without some type of surge. I would also think if only the fuse for front jack were bad the rear jacks would be operational unless there is some mechanism shutting down all jacks if 1 pair is inoperable. No sure about that. If fuses are ok (will check a little later) then I guess I might have a ground wire loose in the bundle. Quick visual inspection doesn't reveal this. One thing is for sure...this has to be electrical in nature as front and rear use 2 different motors.
2013 F350 Lariat 6.7 Diesel DRW
2013 Rockwood Ultralite 2608 WS
2013 Days Camping: 61
2014 Days Camping: 200+
TxTravelingRN is offline   Reply With Quote
Old 01-11-2014, 12:36 PM   #32
fonzie's Avatar
Looking at your DC panel, it looks like the bottom yellow 20 amp fuse is label "PSJ" for power stabilizing jack?? Just to be on safe side, I would pull it out and make sure it is not burnt.
ps: glad your furnace is fix
Fonzie
Old 01-11-2014, 04:10 PM   #33
You nailed it Fonzie. 20 amp fuse was dead, replaced, and stabs are now working.
Called service technician where I bought RV. He looked at same model on site. There is not an external fuse or reset button for this model. Everything is in the panel. Interestingly, the models at RV dealership ALL had 30 amp fuses, NOT 20. I replaced the 20 with a 30 amp as Walmart was out of the 20's. I want to test later to see if it blows a 20 when I use stabs again. Documents I received for stabs was minimal at best and doesn't indicate what proper fuse amp should be used.
Thanks for pointing out the obvious.
furnace
