Old 09-09-2016, 01:18 PM   #1
Sagecoachdriver's Avatar
Defrost issue with Dometic 6 cf fridge
My 2016 Forester has the Dometic RM2652 6cf 2 door fridge. Shortly after I turn it on, the back wall of the freezer begins to frost up. After 4-5 days, the back freezer wall has an 1/8"+ layer of ice. When I return home, remove the food and shut it off, it melts. This causes a pool of water to form on the base of the freezer. The fridge seems fine and any ice that has formed on the evap coils melts, goes into the tray and exits the fridge and MH via a tube. But the freeze water just sits. It appears that it must be somehow leaking down as the fascia woodwork of wrapped vinyl is swelling from moisture at one corner by the base of the fridge. I now go and wipe up the freeze water as quickly as it melts.
Any thoughts? Out of FR 1 year warranty.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 2 trips 5 nights
Sagecoachdriver is offline   Reply With Quote
Old 09-09-2016, 05:05 PM   #2
Head Rambler
That's normal. The freezer compartment is sealed and therefore holds the water from the melted ice.
It's best to always absorb the water from the bottom of the freezer compartment before it overflows the front of the pan.
I know it's a bit of a pain, but it needs to be done.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 09-09-2016, 05:59 PM   #3
sgtlm17's Avatar
X2. The freezer is not self defrost and ice will form. Some people have put those flexible thin cutting boards against the back wall of freezer and the ice will form on the front of cutting board for easy removal. I have not tried it.
2016 Forester GTS 2801QSF
sgtlm17 is offline   Reply With Quote
Old 09-09-2016, 06:56 PM   #4
Old 09-09-2016, 06:59 PM   #5
Does the board on the back wall affect the cooling?
Old 09-10-2016, 05:36 PM   #6
bend302's Avatar
DW always lays a towel in the bottom of freezer to collect water. The ice in the refer compartment melts and runs out tube. Haven't had any leaks from the freezer. We do have to remember to return to storage in a couple of days after we return home to get the towel before things mildew.
Bill
Life is a journey, not a destination.
2005 Georgetown 359ts
Bill & Virginia, Kentucky
Nights camped in 2011...78 , 2012...73,
Nights camped in 2013...123, 2014 ...101
bend302 is offline   Reply With Quote
Old 09-10-2016, 05:50 PM   #7
sgtlm17's Avatar
Cutting board trick does not effect cooling. This is those thin plastic boards you can roll up. You usually get them 2 or 3 to a pack.
https://www.amazon.com/MIU-Flexible-...+cutting+board
dometic, fridge
