Old 06-08-2013, 10:43 AM   #1
BandJCarm's Avatar
Direct TV HD for RV Question
New Guy here, from Arkansas. Just got a Grey Wolf 26BH.
When shopping multiple RV dealers, and also sending online questions, I asked every one of them about how to do satellite TV, especially Direct TV with HD. We aren't about to miss the Cardinal Games just 'cause we're camping!!
Not one of them has a clue. Zero.
I smell a chance to get rich, if I wasn't retired and terminally lazy.
However, before I start my own consulting company I suppose I should at least try to install one of these myself. My goal is to get an HD-Compatible Direct TV Dish, use an HD-25 receiver from my house, and buy a 2nd TV for the camper. (An ulterior motive is to also take this setup to our seldom-used farm house that we inherited, which has no cable at all).
It appears that it's easy to get one that will automatically track a satellite IF you don't want HD!!! But I do (why wouldn't I?). That means getting a SWiM technology Dish. However, they say these are difficult to get tracked onto a satellite.....assuming I can even figure out which satellite to point to!!!
I've read RV Forums all over, and the discussions are either WHOOSH over my head, or not applicable to my situation.
I'm about to pull the trigger and get this unit from Satellite oasis:
DIRECTV SWiM HDTV Satellite Dish Tripod Kit for RV / Mobile / Portable - Installer Oasis
I can't see that I'm going to get any real help, so I'll just figure it out.
BUT, before I do, I would surely appreciate anyone here jerking me by the collar and saying "Hold up! You need to know X and Y and Z".....
Anyone?
Thanks in advance.
Bill
BandJCarm is offline   Reply With Quote
Old 06-08-2013, 11:01 AM   #2
I know a lot about Dish, not so much about Direct. I agree that you would want HD and when you already have DirecTV at home, I think you've found exactly what you're going to need to use. (You are right that none of the carry-outs support Direct-HD.) I see quite a few Direct dishes in the campgrounds I go to so it's clear that people can do it.
First, try it at home using direct connections (no RV wires). Once you get that to work then you can try it in your RV. If you have problems with pointing, I'd just contact a local DirectTV installer and ask them for help. Usually they're glad to help (especially when you're already a customer). Good luck and let us know how it goes!
Old 06-08-2013, 11:06 AM   #3
BandJCarm's Avatar
Thanks Barry.
I already thought of buying this and then trying it at home. BUT, a big problem with that. We had to take out 3 huge sweetgum trees and put the Direct TV dish on the roof to get it to work. A portable dish is going to be much lower here at the house, so short of getting up on roof and trying to mount a carryout dish, I don't see how to do it here!
I have a feeling that what I want to buy will theoretically work, but pointing it and getting it connected correctly seems to be the missing piece of info to me.
Old 06-08-2013, 11:20 AM   #4
jim44646's Avatar
When hooking sat to an RV the cable conection on the side of TT leads to the booster behond TV. The booster needs by passed. I got the neighbors SWM sat. when the went back to cable. It only has a single LNB. I have set it up a few times.
jim44646 is offline   Reply With Quote
Old 06-08-2013, 11:25 AM   #5
I don't know what your tree situation is of course, but you have the advantage that it doesn't have to be on the house. Perhaps you can just set it at the edge of the street (for instance).
I think the company you're buying from will tell you what Sats you need and give you instructions. If you have a smart-phone you will want to get an app to help you locate the satellite of interest before you start the process. That helps a lot. Lots of us do it...you can too!
Does your RV have both "Cable" and "Sat" coax connections on the outside, or only Cable? Hopefully you'll have both and it's just a matter of using the Sat ports both outside and inside to connect the dish to your receiver. Then just an HDMI cable from the receiver to your TV.
Old 06-08-2013, 11:26 AM   #6
Freds342's Avatar
I have an HD DVR in my motorhome, but don't use SWM, so I can use a meter. I have a Winegard SD manual dish on the roof that we use when short-timing, and a 3-LNB High-Def portable that I set up when staying more than a couple of nights. The Receiver stays in the motorhome, and when we're at home, I just use the SD antenna to keep it updated.
2005 Georgetown 342DS XL, Full Banks Package
2005 Liberty Renegade 4X Toad
1989 Wrangler Sahara Toad
1984 19.5' Beachcraft i/o 5.o liter, 4-bbl (and you thought your Moho sucked gas!)
D/W Carole and Maggie the Teacup Lab (Black Chihuahua)
Freds342 is offline   Reply With Quote
Old 06-08-2013, 11:54 AM   #7
BandJCarm's Avatar
The outside has one male BNC connector and it is labeled "Cable/Sat". I don't see why I'd need two, both just use simple BNC coax connections. This is just a plug that ends up in the antenna portion of the TV. If nothing is plugged to it, it doesn't use that. It would use whichever (cable or Dish) is connected outside, I'd think.
No? Yes?
Clearly, it's done all the time, and even an old idjit like me SHOULD be able to figure it out. I'm just hoping that I'm buying the correct dish and equipment!
You know...........I just called the online company I was about to buy the dish from, and they're closed on weekends. I think I will wait to order and call them Monday and hopefully someone can explain all this to me. This can't be that hard, as has been said.
Old 06-08-2013, 12:04 PM   #8
I don't think it's BNC. It's an F fitting. As Jim said, when there's only one, it usually wires to the back of the rooftop antenna amplifier control and there is a splitter in that device (as well as an AB switch). You need to turn the "booster" switch off to get it to pass that signal thru to the internal coax connector, but I believe that it does pass DC voltage which is required for a Sat receiver to LNB connection. If your RV has more than one TV, they might have run that cable thru a non-DC-passing splitter to the TVs and that would have to be replaced.
Old 06-08-2013, 12:35 PM   #9
BandJCarm's Avatar
Man, I'm getting more confused by the minute.
It looks like a standard coax connection. Here is a pic of it closed, and then the plastic cover opened, on the outside of camper. This is the only one of these it has:
This is connected to a port above the tv and then with another coax to the only place this TV has for a coax connection....and it's labeled "RF Connection" on the TV.
I did just notice this is a 12V TV and the only power connection is labeled 12V!!! Then it has a converter to connect to 110 power outlet. I don't know why I'd need a 12V tv, it won't even work without being connected to full 30a service (I just tried it, and the TT is plugged to 15a home electric outlet, and the TV won't come on).
All that says to me, and I may be WAY wrong, that I can plug the outside TT connection to a cable TV coax, or a satellite coax. Not sure how the TV would know the difference.
However, now I'm confused as to how the TV knows to connect that one connection to either OTA antenna or to the connection pictured above???!!??? There is an on/off switch where the coax coming out of the tv connects to an outlet overhead, but the other half of that outlet (physically) is a 12VDC round plug in. So now I'm lost and about to call the dealer's tech and yell Uncle.
Old 06-08-2013, 01:06 PM   #10
It IS a standard coax connection. It's threaded, and that's an F connector. A BNC has no threads and has little pins on it and uses 1/4 turn to lock it on. Not that any of this matters. It's just terminology.
That cable is not connected directly to the port above the TV. That's what Jim was telling you. It's connected to some electronics behind that port. The TV doesn't know anything. You have to tell it if you want Cable or OTA when it scans for channels.
How the electronics behind that port knows what to connect is: Booster on (light), it's OTA. Booster off (no light) it's Cable (or Sat-dish).
If your TV wouldn't power on with your RV plugged into an adapter which is connected to a 15-amp outlet at home then something's wrong. It should.
You should be happy to have a 12v TV. If you have (or can get) the 12v connection wire for it, you can plug it into the "12VDC round plug in" and use it when you're boondocking.
