Old 06-18-2012, 02:22 PM   #1
Direct tv pointing
Is there a web site I can go to to find the pointing for a Direct TV HD dish by zip code.I found some sites but did not have skew,I need skew,elvation and azimuth.I had a zip code chart for DIsh TV,can not find for Direct TV.THANKS
manvel is offline   Reply With Quote
Old 06-18-2012, 02:37 PM   #2
JDWeir's Avatar
It runs in my mind that if you type in the zip code in the setup portion of your receiver menu that it displays the skew. I don't have my receiver set up to check this, so I may be wrong.
TV, 2000 Dodge RAM 2500 Quad cab short bed, Cummins 5.9, Edge Comp, Gauges.
5ver, 2011 Palamino Sabre 31 RETS.
JDWeir is offline   Reply With Quote
Old 06-19-2012, 06:53 AM   #3
You are correct but, I would do it from a setup already up and running. It takes forever for a HR or H receiver to get you to a setup screen from a cold start. Just go into the setup menu and change the zip it will give you the number you need write them down and when you get where you are going make the changes to you dish before powering up the receiver. I hope I made sense
RickV is offline   Reply With Quote
Old 06-19-2012, 07:51 AM   #4
TURBS's Avatar
Www.Dishpointer.com
Good luck!
Old 06-19-2012, 08:01 AM   #5
He is interested in the skew/yaw numbers not just elevation and azimuth.
Old 06-19-2012, 08:26 AM   #6
TURBS's Avatar
he said nothing about yaw.
And everything he did ask for is on that link.
Old 06-19-2012, 07:35 PM   #7
My bad I was on my not so smartphone when I looked at that link and didn't scroll down far enough
Old 06-19-2012, 07:48 PM   #8
TURBS's Avatar
No problem!
I make at least one my bad a day! Lol
Old 06-19-2012, 07:51 PM   #9
onetonford's Avatar
Go to the direct TV site and go to their RV section and they have all the info for setting up the dish I use them all the time......
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
