Old 05-10-2015, 06:21 PM   #1
DISH issue?
Just bought the new dish tailgater. Plugged everything in through the internal hookup. Boom no signal. Go direct dish to receiver. Boom good to go. My question is am I doing something wrong with the internal cable system or do I need to add a satellite specific plate somewhere.
kilntym2 is offline   Reply With Quote
Old 05-10-2015, 07:14 PM   #2
dan-nickie's Avatar
If you are hooking to the outside cable connection, their are splitters in the line that will not pass satellite signals.
You are not doing anything wrong.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 05-10-2015, 09:02 PM   #3
jk510's Avatar
Most likely you are hooking up to the cable in jack on the trailer (motorhome?). That cable runs to the antenna amplifier plate and has a DC voltage blocker to prevent the amp from feeding voltage into the cable system (cable companies probably don't like it). Unfortunately your tailgater (and all satellite dishes) need that voltage to operate. You will either have to run a separate cable to the outside or that the cable off the amp.
Joel K
Southeast AZ
2013 Coachman Mirada 29DSSE
jk510 is offline   Reply With Quote
Old 05-10-2015, 09:46 PM   #4
Left Coast
NEED more info.....year and type of rv, brand.
