Old 08-04-2014, 10:18 AM   #1
Display clock on Kenwood KDC-152
Our new Rockwood A192HW camper came with an AM-FM radio and DVD player. It is a Kenwood KDC-152. I have looked at the manual and it shows you how to set the time on the clock but no information on how you can display the clock after you have set the time, unless you press Function->Settings->Clock. It would seem that once the time is set the clock should be displayed while you are using other functions such as the radio or DVD player. Anyone have any ideas on this?
Jack
macjack39 is offline   Reply With Quote
Old 08-04-2014, 10:24 AM   #2
Jack
Check out page 5 here:
http://manual.kenwood.com/files/52d48aa8a46e8.pdf
If you press the SCRL DISP button, does it get to the clock, and then does it stay there? If it changes between trips, are you disconnecting batteries or anything which might 'reset' the unit and go back to another default display setting?
2015 Grey Wolf 26DBH
2013 Toyota Tundra 5.7 CrewMax
COHR is offline   Reply With Quote
Old 08-04-2014, 12:20 PM   #3
Thanks. Will try your suggestion
Funny, I had not noticed the SCRL DISP button before. I will try that the next time I have the camper up. Thanks again.
Jack
Old 08-04-2014, 03:25 PM   #4
Jack
No worries, and good luck! Always helps me to have a second pair of eyes on a problem. I bet that'll be your solution.
