If I were you I would give Dinosaur Electronics a call:
Dinosaur Electronics Home. High quality circuit boards for RV appliances.
Their customer service is excellent and I am certain they will help talk you through the troubleshooting of your board.
IF the board is bad they sell a replacement board that is less expensive and better built than the factory board.
You will be well and truly pleased with them.
PS, consider an adjustable thermister from them as well. It will help you regulate yoru reefer temp much better thant he factory setup.
NO I dont own stock in them, I have just had EXCELLENT results with their products in the past.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
