Old 08-09-2015, 12:51 PM   #1
The Big Ragu
gagliacr0609's Avatar
DMR702 Replacement Door Shelf
We have a 2015 Rockwood SUL 8280WS with a Dometic DMR702 fridge. We noticed that our middle door shelf is cracked and can't seem to find the replacement. Has anyone found a parts list or replaced refrigerator door shelves for this unit? Any help would be appreciated.
gagliacr0609 is offline   Reply With Quote
Old 08-09-2015, 04:44 PM   #2
DMR Parts
I wondered about this model as it is new. There were several models already made and don't understand why another was added except for less weight.
I'm afraid you will need to contact dealer first and/or Dometic by phone or website. The installation manual online did not list parts as I'm concerned about the control board and its ignition cycle (or lack thereof).
whatsupchuck is offline   Reply With Quote
Old 08-12-2015, 08:42 AM   #3
The Big Ragu
Thank you. I thought that may be the case. Good luck with the ignition issue. I almost always run on electricity and have not really used to propane system for the fridge except to purge the lines and verify that the system works. I recall the service tech mentioning that it took a while to purge the lines with this unit and assume that it is because of the single shot ignition.
door, replacement
