Old 02-02-2018, 06:11 PM   #21
Originally Posted by Schwartzworld View Post
A very small and compact inverter would be cheaper than trying to convert 12 volt DC to 24 volt AC.
And horribly inefficient. Bottom line, I don't want it *that* bad.
I someday want to try 12 or 24vdc and see if it works on the thermostat I want to use.... But somedays are hard to find.
aeblank is offline   Reply With Quote
Old 02-02-2018, 06:20 PM   #22
Hunter battery operated from Walmart, HD, Lowes, Amazon. Good for A/C and heat. Don't get a heat only. Someday you will and to use your A/C. Very easy read direction to install.
fan, thermostat
