Closed Thread
Old 08-17-2011, 05:00 AM   #121
I have used a setup like this when getting noise in a amateur (ham) radio. I can't tell from the above picture what the current flow is for the diode, but a 4700 micro farad capacititor is a bit large for a DC stereo, IMO. There shouldn't ever be much current draw from a stereo. When I made the "homebrew" filters for a 100 watt transmitting radio I would only use a 1 pico farad betweem DC+ and DC-. By using a 4700 micro, I guess they are planning of a lot of AC on the DC line. Perhaps a shortcut for a electricly noisy power converter? Just a thought.
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline
Old 08-17-2011, 06:58 AM   #122
Herk7769's Avatar
Yup that is a diode not a resistor.
Back to poorly wired up and a short occurred.
There is almost no way that 6 amps went through that diode without a dead short. If you had hooked it up backwards, the diode should have blocked current flow.
However, it has been a LONG time since I played with this stuff in college.
HAM CALLSIGN - KC3FFW
Herk7769 is offline
Old 08-17-2011, 07:23 AM   #123
Bob I m still trying to solve my problem. I sent you pictures and since have found the grey coax from the concertone is also loose and has a similar piece of metal attached. I think it is a splitter that somehow has come apart.So I have the cable behind the plate the tv hooks to and from the concertone both loose and I am sure there is a splitter somewhere that has come apart. any idea where to look. I have taken the tv amplifier plate off and I see a splitter but cannot get to it without cutting a larger hole. could this be the one.If so what other wires are attached to it?Is there a wiring diagram available for all the coax inputs including antenna amplifier.
Bill And Theresa Perry, At Lake Gaston
2004 R Vision Trail Lite
2003 F 150 Super crew with 5.4 Tow package
bill and theresa is offline
Old 08-17-2011, 08:03 AM   #124
Now, do I need it?
Me, Her, Boy(8), Girl(7), Baby Girl(1.5) and Dog
06 Chevy 2500 4x4 crewcab SB Duramax/Allison
08 Flagstaff 831BHSS w/ Reese Dual Cam
"Submarines once, submarines twice..."
dc31bhss is offline
Old 08-17-2011, 12:37 PM   #125
I decided to attempt to find my problem and I removed the metal grilldoor for the bass speaker and removed a small stapled panel and the 4 way splitter was visible and 3 of four cables had separated from the splitter and each had a small piece of it attached.I am off to buy a new one and see if that cures my problems. was wondering why I could get no antenna or cable but I could get satellite. Last campground had cable and I ran thru slide gasket to tv. worked great.
Old 08-18-2011, 05:19 AM   #126
Originally Posted by dc31bhss View Post
Now, do I need it?
If there isn't any noise (hums, poping, whines, etc) while your listening to the Concertone, then I would say "no", but if you do have noise, you may want to put one back in. Most would probably blame the equipment for the noise, but now that you know you had a filter you have some place to start. You can probably get one at a car stereo store. I would say to check Radio Shack but all they seem to worry about anymore is selling you a cell phone, and the clerk probably wouldn't even know what you were asking for.
Because most of the DC power comes through the power converter (AC to DC) the DC power won't be as "clean" as coming direct from a battery. Even if you were connected straight to you battery, your battery charger/ converter is connected to the battery, noise potential. I could get more technical about "noise" but I can get carried away, so the DW tells me.
Kirk, KN1B
Old 08-18-2011, 08:24 AM   #127
Thanks everyone for the help. My electrical knowledge has dwindled since my high school car stereo days. We'll see how she goes this weekend. COME ON FRIDAY!!
dc31bhss is offline
Old 08-18-2011, 09:35 AM   #128
Installed a new 4 way splitter and still get no signal. I wired directly from ant amp to converter box and then to tv and I get 11 local stations. So I must have the wrong in connection on the splitter. just got info on here for the amp plate so the antenna out should be the in on the splitter. I will try again.
Old 08-18-2011, 10:19 AM   #129
Just traced wires and I have the right input so I am not sure what is going on. am getting a little frustrated trying to contact forest river or concertone for help and of course leave a voicemail which I have for 4 days with no replys except for Bob
Fields he did answer my e mails with questions then nothing. I am sure he is busy.
Old 08-19-2011, 09:29 AM   #130
well I give up. I get good sound but no picture. I bypass the concertone an install my converter box from amplified antenna to tv and get 11 locals. with the three rca plugs into input 1 and set the concertone to input 1 I get good surround sound. I guess I will just use it for sound. No dvd so I will purchase a dvdplayer.Jonathan from rockwood did return my call and assured me I had the splitter hooked up correctly. I guess the concertone went bad and lost video. even tho it has worked perfectly since I purchased the camper about a year ago.
Closed Thread
