Old 08-24-2014, 08:02 AM   #21
Crusadernoob's Avatar
Originally Posted by BiigDaddy View Post
Regarding your switch, you turn yours on and off manually instead of the refrigerator cycling the fans on and off itself? Awesome fan setup, by the way!
Yes, I took the B+ supply from the factory temp sensor and sent it to my switch. I usually turn my fridge on the night before we go out and didn't think the fans needed to be running all night, but living and camping in the south I wanted them on all the time when in use, we will see how it works, or doesn't work, on our next trip.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37, 2020 26, 2021 28
Crusadernoob is offline   Reply With Quote
Old 08-24-2014, 08:59 AM   #22
dcheatwood's Avatar
My old fan cycles as installed. My two ad-ons are switched. Only use them on the hotter days.
2018 Forester 3011 DS
Old 08-24-2014, 09:26 AM   #23
I had no fans in mine and on HOT days I couldn't cool anything and any ice in the freezer was water. I added 5 fans with two of them mid way up between the coils and three at the very top of the vent shaft. I do have them controlled by a switch. I always run them at the start of the set up to cool the RV refrigerator down Quick. They will generally stay on the whole time we are camping. With the vent shaft being on the outside wall, if there is any direct sunlight on it and particularly on a hot day, it is like an attic inside of it. I want my freezer stuff to be Frozen and my refrigerated stuff to be Cold. And it is.
OKI Marine is offline   Reply With Quote
Old 08-24-2014, 09:44 AM   #24
OKI Marine, thanks for all your info, like I said in earlier post I already ordered mine before I got your message, I sure hope this works! Would like to see pics of what worked for you, those 3 are at the top and all I could do was 1 more at the bottom, time will tell.
Old 08-24-2014, 11:23 AM   #25
Crusadernoob. That looks pretty good. I like the location of your switch. Hope that set up works well for you. Looks like you did a really good job on it. I will need to get some pics of my setup and post them for others to see.
Old 09-21-2014, 08:23 PM   #26
wowzer's Avatar
Well....had my camper in the shop to look at the fridge. They told me they cleaned the burner unit real well. Good news...been on 2 outings since then and it has been working great. Huh...who knew.
Jim and Sherri Brown
2013 Silverado 2500 6.6 DuraMax
2012 Sabre 34REQS6
wowzer is offline   Reply With Quote
Old 09-21-2014, 09:50 PM   #27
DDC
DDC's Avatar
Did this thread ever get off topic, the op's original question got lost, thankfully he managed to get it fixed.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
