Old 08-23-2014, 06:25 PM   #1
wowzer's Avatar
Does this look right to anyone???
Was troubleshooting my fridge to see why it doesn't work on LP all that well. Opened up the top vent area and found this board across the opening. Now I ask....is this right???
Jim and Sherri Brown
2013 Silverado 2500 6.6 DuraMax
2012 Sabre 34REQS6
wowzer is offline   Reply With Quote
Old 08-23-2014, 06:33 PM   #2
Me thinks you might have a circulation problem Sir!
Old 08-23-2014, 06:44 PM   #3
If you look up your fridge model on how to install, I believe it is correct and done to create a chimney effect to get rid of warm air. You probably have one fan behind there and you could add another. That is the way my dometic 2852 install is.Should not be related to propane operation.
livewire is offline   Reply With Quote
Old 08-23-2014, 06:47 PM   #4
dcheatwood's Avatar
Yes. Normal. Mine and many other came like that. There's some discussion here on other frig problem threads. Tho yours does seem higher than usual. I think the ideal is to get the air to pass thru upper fins before exiting the upper vent. I cut mine out when I installed two more fans.
2018 Forester 3011 DS
Old 08-23-2014, 06:48 PM   #5
dcheatwood's Avatar
PS. I watched a windjammer employee install the boards in the factory a few week ago.
Old 08-23-2014, 06:53 PM   #6
CCRVOC
Ramblin Recks's Avatar
I cut mine out when I installed two more fans.The fridge is much cooler now.
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 1000w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
Old 08-23-2014, 06:54 PM   #7
I think that I would mount a few high speed, high CFM 12V computer fans in that board
OKI Marine is offline   Reply With Quote
Old 08-23-2014, 07:10 PM   #8
wowzer's Avatar
Hmmmmm now I'm even more confused. So there's two schools of thought about the boards functionality then.
2012 Sabre 34REQS6
Old 08-23-2014, 07:15 PM   #9
Ford Idaho's Avatar
If the factory installs them then they are there for a reason.
Antec 761345-75081-3 Case Fan - Newegg.com
Old 08-23-2014, 07:20 PM   #10
Witch Doctor's Avatar
The board is only put there to stop any down draft, Get rid of it because it is causing you not to have a free convection flow or add some fans to overcome the resistance the board is creating. In other words it's stopping the air flow over the coil area or holding it in making your cooling a lot less capible of heat transfer. The more air over the coil the better cooling you will have. Both Decheatwood and Ramblin ricks are correct IMO. But that is just me.
Coachmen M/H
Concord
2018 / 300 DSC
Old 08-23-2014, 07:53 PM   #11
CCRVOC
This instruction from Dometic shows FR took some liberties for a refer slide installation
http://bryantrv.com/docs2/docs/dometicventing.pdf
Old 08-24-2014, 12:22 AM   #12
dcheatwood's Avatar
Now that is interesting as there was no upper nor lower baffle behind my frig. I made an upper and now will make a lower one. That looks like a way to get the air to flow thru the fins better as air must flow up right against the back of the frig.
Old 08-24-2014, 02:54 AM   #13
On page #6 is how mine is done and it is a Norcol, Looks like they stole OC'S curved top to help exhust the hot air......and as a side note OC' has a lot of it, but he told me to do that years ago to mine. I guess I should listen to my ELDERS....
Coachmen M/H
Concord
2018 / 300 DSC
Old 08-24-2014, 03:04 AM   #14
I don't have a lower baffle either. I would be interested to hear how it goes for you. I can see where it would make the air flow more efficient, but also fairly restricted without sufficient secondary draw (fan). It will be interesting to see if efficiency trumps the reduced volume.
rana is offline   Reply With Quote
Old 08-24-2014, 06:33 AM   #15
Crusadernoob's Avatar
Mine had the same thing in it, thought it was weird so I cut it out only to find one little fan behind it, no wonder we couldn't keep ice cream frozen. Well, I spent some time and installed these, haven't been out with it yet, but it's only got to be better, I guess I should have done some more reading up on this, now I need to chek on the baffles. Oh well.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 36, 2019 37
Crusadernoob is offline   Reply With Quote
Old 08-24-2014, 06:54 AM   #16
That's some serious fannage! What kind of juice does one of those pull? Did you purchase them online?
~Cheers
Old 08-24-2014, 07:23 AM   #17
It's not much, .13amps each, made sure I got ball bearing for high life, I ordered them off of newegg.com but I must say I inquired about this project from another member and had already ordered them before I was told about coolerguys.com At coolerguys.com they have all the power boards, extension cables you would need depending on your install. I just used the factory power supply, added a switch to the refrigerator panel. I also put a 4th fan below. I sure hope this helps, we love our ice cream with a spoon, not a straw.
Old 08-24-2014, 07:30 AM   #18
BiigDaddy's Avatar
Regarding your switch, you turn yours on and off manually instead of the refrigerator cycling the fans on and off itself? Awesome fan setup, by the way!
2013 GMC Savana 2500 FBI Edition
2015 Rockwood 8327SS stuffed with 5 kids!
SE Michigan
Nights camped 2014: 48
BiigDaddy is offline   Reply With Quote
Old 08-24-2014, 07:31 AM   #19
.52 for all 4... that's certainly manageable. Thanks for the info, Ethan!
~Cheers
Old 08-24-2014, 07:54 AM   #20
wowzer's Avatar
Well..had my fridge on LP for 24 hrs. I can put my hand on the canister and it's barlry warm and fridge is warmer. I'm thinking it's more than just and air flow problem. Damn!!
2012 Sabre 34REQS6
