Old 03-27-2016, 05:56 PM   #1
Does tv sound play through irv66
We just picked up our Rockwood 2304DS last Thursday. Everything seems to be working good but we had a question. Are you supposed to be able to play the tv sound through the stereo speakers? If so is there a trick to it? We put it on the TV Audio mode but it doesn't change over. Wanted to make sure if it's even supposed to or if there is something wrong with it. Any input is appreciated. Thanks!!
kaytrimm is offline   Reply With Quote
Old 03-27-2016, 06:12 PM   #2
Kaadk's Avatar
It's probably not wired for it from the factory. But it's easy to add your own. Just pull the radio from the wall and check what inputs you have on the back then hookup the right cable between the two.
There's no use crying over spilt milk, unless it's on your keyboard.
Old 03-27-2016, 06:19 PM   #3
Well Nevermind, lol I thought we had tried every SRC but evidently not. 😳 I just chose the DOT/DCC IN and it started working.
Old 03-27-2016, 06:28 PM   #4
Georgia Frog Rally 2018
aceinspp's Avatar
Yep as you found out. Later RD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 03-28-2016, 07:13 AM   #5
jeff64's Avatar
If this is what you are experiencing then the OIC (optical interface) cable is installed between the two units. For TV Audio in(SRC button) to work, the two are connected through the RCA audio output on the TV. I went down this road last year with an annoying buzz in the surround sound caused by a defective Toshiba TV that I finally convinced the dealer it was bad. They replaced it with a Furrion (has RCA out but, no OIS). So, if you have to get a new TV and it has to work with the iRV66 that's the skinny on the hookup. Good luck finding a HDTV with RCA phono plug sound output. OIS ouput is pretty standard on HDTVs out there
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 03-28-2016, 10:44 AM   #6
I have this same audio system in my Flagstaff 2016 just got it home. You found the correct source took me a while to find it too. The one thing I notice is if you just have radio on and set volume to 1 it is still quite load. Anyone else find that, could I be missing another setting? TV surround sound is OK. I can turn it low enough.
Sdsmore is offline   Reply With Quote
Old 03-28-2016, 08:34 PM   #7
Rockwood Ultralite 2304DS IRV66 stereo
Yes, you can. I called my salesman about this and he did not know. He said that I would have to speak to their service tech. That would be a hassle, so I figured it out myself. With your TV a stereo on go to the source of the stereo and choose ARC. It should play your TV through the stereo.
Wildhog3213 is offline   Reply With Quote
Old 03-28-2016, 10:57 PM   #8
Have the same problem with our new 2304KS. The manual is useless.
I used a stereo cable, 1/8 " male jacks both ends, connecting the headphones out on the tv to the auxiliary input on the irv. I scrolled through the selections to find the one that works. On the plus side, the Bluetooth connection works great for connecting the irv to the pandora app on my iPad or phone.
Denny B is offline   Reply With Quote
