Old 09-20-2016, 10:36 AM   #1
Does your T-stat do this?
We have a 2104S TT which has a Coleman-Mach thermostat. Have had trouble turning on the furnace the last two mornings. Slide the fan switch, on t-stat, to high or low and auto. Then slide the other switch to heat and nothing happens. After sliding the switch from off to heat a half dozen times the fan will start and we have heat. The T- stat works every time for the A/C. Sure seems like the thermostat issue to me.
The unit is under warranty. Just wondered if others were experiencing the same "shivering" effect.
CynReed is offline   Reply With Quote
Old 09-21-2016, 09:53 PM   #2
Just an update to our thermostat problem....turns out the issue was a stuck sail switch inside the furnace. Our dealer was able to remedy the problem under warranty.
Old 09-21-2016, 10:08 PM   #3
Dazed & Confused
M&K Hoffman's Avatar
Good to hear. Thanks for sharing.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
