Old 03-03-2015, 12:00 AM   #1
Domestic 2652 too cold ?
I see the plastic slide piece on the fin right side of frig that slides up/down to control the frig. There is a prode that just hangs on the shelf that is not long enough to attach to the plastic slider (I assume that the temp prode) and my food gets to cold/cup of milk gets ice in it and the fins slightly ice up. The prode is on the bottom shelf just hanging and I placed a gauge in there that reads 28-30 . First time camping for several months verse a weekend so not sure about the ice on fins. I assume the freezer part just gets cold as it wants-see no controler for that. Thanks
Racer310 is offline   Reply With Quote
Old 03-03-2015, 05:35 AM   #2
Witch Doctor's Avatar
I would call Domectic, they had a new fix for that they were sending people.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 03-03-2015, 07:02 AM   #3
dcheatwood's Avatar
My "probe" was too short to reach tje slide also but I gently pulled the wire and there was plenty of slack that came from the outside.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 03-04-2015, 01:53 AM   #4
Thanks for the info, appreicate it.
Old 03-04-2015, 04:10 PM   #5
GerryW's Avatar
I had the same problem in my 2300. It looked like the probe had no control. I pulled on it to get a bit more length aand now my frig runs at 40. Go figgur. Since it's a new unit I will see the dealer when i get home in April. it seems to be a dumb way to control temp. Other than that the frig is fine.
GerryW is offline   Reply With Quote
Old 03-17-2015, 01:38 AM   #6
Called Domectic and all the girl could say is connect probe to plastic slider...she really was not listening to me. The probe barely fits in the slider which is down to bottom of fins (warmer gauge mark). Meanwhile I defrosted the fins. Put 2 different temp gauges in the frig and now I have 2 different temps which are 8-10 degrees diffence, go figure that one. 1 gauge-sysco reads 28 and the other unbrand name gauge reads 38 so I don't know which is right. I guess I could get a 3rd gauge to compare the other two, lol
Old 03-18-2015, 12:04 PM   #7
On mine the probe was bad - frig never shut off - froze everything.
Bought a probe kit at a dealer - splice into existing wires - it worked fine after that.
cadman99 is offline   Reply With Quote
Old 03-18-2015, 02:20 PM   #8
Thanks for info. May have to do that.
Old 03-25-2015, 12:26 PM   #9
HarrynSally's Avatar
http://youtu.be/OmzDYZFYmx0
Try this see if it helps
HarrynSally is offline   Reply With Quote
Old 03-25-2015, 12:34 PM   #10
Need to put your thermistor on the second fin where it is cooler and your run time will be shorter.
