I've got a Coachman Concord brand new, with a Dometic frig that has no temp controls. Just an on/off switch. Automatic/Gas and Check light. I just otice all this as I'm doing setup for going away. My frig is on electric. How do I adjust temps. Thanks
You should see a diagram on the inside of the fridge that shows which way to move the slide to increase or decrease the Fridge temp. Note it usually takes 8-12 hrs for an empty fridge to reach temp. Longer for loaded fridge.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
There was no diagram and not even this booklet... thank you I copied it and printed it out.
I am letting it set for two days before I start loading it up
Bob, looks like I need to pick up a thermometer for sitting in the frig.
Stay tuned in cause I'm sure I'm gonna have a few more surprises.
Again thank you for helping. This is a new type of frig for me
