Old 07-03-2016, 06:50 AM   #1
Dometic 13.5 ac leaking water
So last night around 1 am or so i woke up to wster coming from our front ac on a HG 356qb. The water was dripping out of the control knobs and intake.
I turned the system off and immediatly pulled the lower end. I observed no signs of icing on the coils.
Could my drip pan be causing this. It was quit a bit of water..
KIPKERS is offline   Reply With Quote
Old 07-03-2016, 08:35 AM   #2
ilmor's Avatar
This can happen when the condensation water isn't getting out of the a/c at all or quickly enough. If it were me I would go up on my roof, remove the a/c cover, run the A/c and observe. Locate where the condensate should be coming out to make sure there are no obstructions, both where the condensate exits the a/c as well as where it exits the pan.
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
Old 07-03-2016, 08:50 AM   #3
SeaDog's Avatar
There should be a drain hole or tube from the indoor coil to the outside tray if this becomes plugged water will build up inside and it has to go somewhere. go up on the roof pull the cover and find the drain coming from the indoor coil and clean it out.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 07-03-2016, 09:26 AM   #4
Thank you for the quick reply. Ill try and pull it today
Old 07-03-2016, 12:03 PM   #5
It could also be the gasket between the AC unit and the roof. Sometimes these just need to be tightened up. You should not over tighten them however. If you need a new gasket, I have one I will give you.
AS Rabbit
2016 Wildwood 195BH
2009 Silverado 1500
Asrabbit is online now   Reply With Quote
Old 07-03-2016, 12:46 PM   #6
TURBS's Avatar
Torque on the gasket mounting bolts is 45 inch lbs
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "10"
Old 07-03-2016, 01:30 PM   #7
Head Rambler
I'd check the gasket bolts first. They're easy to check and if they're a little loose it's an easy fix.
45 in lbs is only about 4 ft lbs, so not much torque. The real key is to evenly tighten the bolts. Just screw them in until they touch the surface and then cross tighten them until they're at the proper torque.
Gotta go campin!
dometic, leak, water
