Old 07-05-2016, 11:01 AM   #91
kc5mhb's Avatar
Originally Posted by Davidg View Post
Interesting...Please keep us informed.
David,
It was just a complaint to the consumer protection division. I have the paperwork but did not complete it. Dometic doesn't need to know that and all that would be done is a letter would be sent to them stating that there was a complaint filed. Just paperwork, but the mere mention is enough to raise eyebrows. It's at the shop now getting a Coleman. More than likely I'll have to pony up and pay the difference but it is worth it to not have to keep going to the dealer for the same thing.
2015 Cherokee Limited 274DBH
2000 F250 CC SD V10 4X4 8' bed, 4:30 gears, SCT X3
2007 Mustang Convertible V6 - Lots of GT mods
1965 Mustang Coupe I6, 3 spd. manual
1963 Thunderbird Landau 390
kc5mhb is offline   Reply With Quote
Old 07-05-2016, 05:13 PM   #92
Originally Posted by kc5mhb View Post
David,
I hear ya. The local shop swapped mine out today. When I picked it up, I asked the service manager if Dometic had made any manufacturing changes to the replacement units, and his reply was "not to his knowledge,....they just keep swapping them out until the 2 year warranties run out, after which the customer gets to pay for it." Kinda sad really. I also asked him what would be involved (when it fails after the warranty runs out) to change it to a Coleman. His answer was that a new thermostat and new wiring would need to be pulled. I get the thermostat, but not the wiring. When I asked him to be more specific, he couldnt do it....just that the Coleman used a different "system".
There may be factors here that I'm not aware of, but I'm not altogether comfortable with his answer. I suspect that he just didnt know.
Another thing I found interesting was that Coleman allowed the dealer to replace a defective unit with the repair centers "in stock" inventory, but Dometic would not because they wanted to track serial numbers to a customer. I'm sure that so that once the two years are up, the customer gets to write a big check.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
Davidg is offline   Reply With Quote
Old 07-05-2016, 05:21 PM   #93
kc5mhb's Avatar
The Coleman uses more wires because the control is different. The Coleman has switches instead of an electronic interface even though they have a digital display. From what I understand, they are more like a home thermostat than the Dometic one. You will also have to pay for the interior trim and filter. Look to pay about $250 to $300 to do a swap if your repair center will take the Dometic on trade. On the Dometic warranty, it is my understanding that every new unit has a 2 year warranty regardless. So if you replace it the warranty starts new on the new unit. I may be mistaken but its what I was led to believe.
Old 07-05-2016, 05:40 PM   #94
Iwannacamp's Avatar
Everywhere else in the world it is based on the original warranty purchase date...unless it is a prorated warranty and you pay a usage period..like tires and batteries.
Our new 5er 10-26-16
Days camped 2016 8
Old 07-05-2016, 05:41 PM   #95
Iwannacamp's Avatar
Y'all hurry up and use up the defective units... I wanna get a new 5er someday
Days camped 2016 8
Old 07-05-2016, 06:41 PM   #96
Citrus County, Fl.
GL1800Rider's Avatar
I was told the warranty is from the original purchase date which means i have 11 months left off I need a third replacement
2016 Forester 3011DS
2015 Toyota Corrola S toad
99 Terry 31G
GL1800Rider is online now   Reply With Quote
Old 07-05-2016, 07:09 PM   #97
The warranty time was another thing we discussed. The warranty starts at purchase of the RV, and runs for 2 years. If you have a defective unit swapped every month, you will pay out of pocket for unit #25. (I know the math works out different from that, but you get the drift...)
Kc5mhb, thanks for the explanation of the difference in the 2 systems. I may, one day, have to pull some new wire.
Dometic is turning into junk, like almost everything else RV. I keep expecting to arrive at my destination one day, towing what looks like a string through a bunch of Campbells Soup cans.....No disrespect intended to Campbells Soup.
Old 07-05-2016, 11:39 PM   #98
kc5mhb's Avatar
At the rate these good companies are being bought out and consolidated, I wonder where we will be in 10 years. Dometic bought out Duo Therm and Atwood. Other companies are doing the same. I guess the biggest issue is the new refrigerant they are forced to use. While we are pushed into following the law, they free vent the stuff down in Mexico. R12 and R22 were the best there ever was. I remember camping as a kid and my uncle kept his trailer like a meat locker. Can barely keep them cool now. Well I'm close to the 2 year mark so I bid adieu to Dometic. I think Coleman has an extension to their warranty for a few more years for a couple hundred dollars. I'll have to ask about that. I'll also get the exact answer on the wires from my repair center. They should be done by Thursday.
Old 07-07-2016, 10:53 PM   #99
I purchased 3 years of extended warranty on my Dometic Brisk Air 15,000 roof air today. Cost is $166.90. This is for 3 additional years. I dont usually buy these warranties, but with the failure rate of these units, it seemed prudent.
You can find it here; https://www.edometic.com
Old 07-07-2016, 11:24 PM   #100
kc5mhb's Avatar
I just went with Good Sam as my warranty with FR is almost up. Aside from some cosmetic items, loose water heater fittings, bad slide seal and a faulty LED light strip. I Ve been pretty lucky. Those air conditioners though are bad news. FR should drop them for Coleman.
15000 btu, 320 bhds, coachmen, cooling, dometic, lakewood, lakewood nj, air conditioner
