Old 05-26-2016, 07:44 PM   #61
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
I question why Dometic does not have recharge connections in their units? A high-side and a low-side connection would allow recharging. I'm not sure ANY OTHER air conditioning unit don't have recharge valves. The units in my cars, boat, truck all are rechargeable.
If my units ever fail, I will install valves in both sides, pump them down and fill them myself.
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 05-26-2016, 07:59 PM   #62
TURBS's Avatar
Dometic 15,000 BTU A/C Failure
Put me down for a junk 15k.
First time to use it since the purchase of the camper.
Turned thermostat to 72 this morning, camper was 83 when I got home, outside temp is 85
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "5"
2015 nights camped "34"
Old 05-26-2016, 08:03 PM   #63
TURBS's Avatar
Someone should do a poll on 15k units
2008 2500hd Duramax
2015 Columbus 320RS
Old 05-26-2016, 08:24 PM   #64
heavynlori's Avatar
2008 2500hd Duramax
2015 Columbus 320RS
Did it work during PDI ???
Sent from my iPhone using Forest River Forums 🇺🇸
heavynlori is offline   Reply With Quote
Old 05-26-2016, 08:28 PM   #65
TURBS's Avatar
It was 40 degrees during pdi.
2008 2500hd Duramax
2015 Columbus 320RS
Old 05-26-2016, 08:44 PM   #66
Perhaps the genny mod didn't work out as well as you thought?
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 05-26-2016, 09:27 PM   #67
kc5mhb's Avatar
If I had to guess, it would be for a couple of reasons. Since there is a warranty involved, this removes user tampering or dealer attempted repairs. There is a functional difference from refrigerant systems using R22. The newer R410a operates at almost double the head pressure than R22. To be precise, R22 operates at 260 psig where R410a runs at 418 psig on the high side. Low side pressures are 76 psig for R22 and 130 psig for the R410a. I can guess they don't want to chance a law suit from one of these things blowing up on someone trying to work on it. (For more info: The Essentials Of Working With R-410A) That is a generic article but an interesting read.
Just my .02
2015 Cherokee Limited 274DBH
2000 F250 CC SD V10 4X4 8' bed, 4:30 gears, SCT X3
2007 Mustang Convertible V6 - Lots of GT mods
1965 Mustang Coupe I6, 3 spd. manual
1963 Thunderbird Landau 390
kc5mhb is offline   Reply With Quote
Old 05-26-2016, 10:25 PM   #68
Phat Phrog Stunt Crew
elind's Avatar
My 15k & 13.5k stilling work good with even some hot desert use after two years.
2014 Wildcat 327ck
2015 129 nites
2016 63 nites
elind is online now   Reply With Quote
Old 05-26-2016, 10:36 PM   #69
TURBS's Avatar
Actually someone at Forest River Columbus should be very very ashamed!
2008 2500hd Duramax
2015 Columbus 320RS
Old 05-27-2016, 07:27 AM   #70
"blind"--Is your unit a Dometic 1500 BTU or different brand unit?
Thurman is online now   Reply With Quote
15000 btu, 320 bhds, coachmen, cooling, dometic, lakewood, lakewood nj, air conditioner
