Old 07-16-2019, 02:00 PM   #1
Dometic 8501 will not turn off
Our Dometic 8501 will not turn off. Possibly a problem with the control buttons. How can the control buttons/panel be removed and inspected?
The fridge is currently on propane and power source also cannot be changed; button is unresponsive. If gas is shut off, fridge attempts to restart. How can we stop propane without harming the fridge?
Dave
Lite is offline   Reply With Quote
Old 07-16-2019, 03:24 PM   #2
A32Deuce's Avatar
Pull the 12 volt fuse. That should shut it down.
A32Deuce is online now   Reply With Quote
Old 07-17-2019, 08:32 PM   #3
Where is fuse?
Hi. Thanks for reply. Where would the 12 volt fuse be. At fridge or in the converter? When I pull the fuse in the power converter w/distribution panel the converter board starts beeping and red lights come on. I ended up removing the main fuse in the converter.
Dave
Old 07-17-2019, 08:48 PM   #4
There should be a 12V fuse in the panel that powers the fridge. Unfortunately, it will also likely power other things too like the water pump and water heater. That depends on the trailer manufacturer and how it was wired.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is online now   Reply With Quote
Old 07-19-2019, 05:48 PM   #5
Dave
Have you tried turning off the power to the TT/RV and the 12V power to let it reset? If the power button doesn't work a reset of power may restore operation. Leave it off for at least 20 seconds. I assume you have turned off the refrigerator before and know you have to hold the button for a few seconds(at least 5 seconds)? Are you getting any fault indication from the fault led on the control panel? If the gas is shut off and it is attempting to reignite you can not change any functions until it completes ignition. If you reset the power it may attempt to resume igniting the gas as the last source so let it ignite before attempting to turn it off or change the power source.
dave1650 is offline   Reply With Quote
dometic
