Auto means fans will always run, typically with 2 AC's they are ducted together, so your second AC will blow cold out to the middle ducts. Is the thermostat in the zone 1 area or zone 2? Typically one of the zones has a thermistor, and if that is blocked or went bad, it could cause the issue.
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
