Old 10-13-2013, 05:13 PM   #1
Dometic A/c FILTERS
My new Prime Time Sanibel had two (2) Dometic ducted A/C units. Does anyone know how to access the filters (if any)?
Kayo
2014 Primetime Sanibel 3051 pulled by a 2013 Chevy Silverado 3500HP dually diesel. Full timers wince 2003 with DW of 53 year. NPS Park Ranger
kayo is offline   Reply With Quote
Old 10-13-2013, 05:30 PM   #2
rskrbina's Avatar
I don't have a Sanibel but I do have a Dometic ducted A/C unit. There is a black plastic screw on the end of the filter housing. Just turn it counter-clockwise with a flat screwdriver and the housing will come off and then remove your filter. Hope this helps
rskrbina is offline   Reply With Quote
Old 10-13-2013, 07:26 PM   #3
The filters are foam behind each of the return vents located on the ceiling in the living room and bedroom.
Old 10-13-2013, 09:21 PM   #4
Denver, CO
garbonz's Avatar
foam filters are a waste of time. they filter essentially nothing. if you really are concerned, then get a small HEPA filter at walmart.
i leave my foam out to improve the airflo and reduce freezing up
2017 Fuse 23T
Old 10-14-2013, 08:22 AM   #5
Originally Posted by garbonz View Post
foam filters are a waste of time. they filter essentially nothing. if you really are concerned, then get a small HEPA filter at walmart. i leave my foam out to improve the airflo and reduce freezing up
Mine had a lot of "nothing" on them that I washed off when I cleaned them.
dometic
