Hot and humid is not the time to set the AC to 65 and let 'er rip.
A brief explanation of AC techniques can be helpful in understanding why.
Air Conditioners need to remove the humidity from the air before it can start really cooling efficiently. To do that, the air conditioner must cycle on and off to let the frost/ice melt into the drip pan and run off the roof.
There is a sensor on the cooling coils that prevents the compressor from running when the coils ice up. This is to prevent the compressor from overheating and become damaged.
So how do I use my AC in hot/humid?
I set my thermostat to 10 degrees below the outside air temperature (or 90 if it is over 100 degrees outside). This gives the AC a chance to start dehumidifying the air by cycling on and off to maintain the set temperature.
Believe me when I say that walking into a 10 degree cooler interior feels good (not great, but good).
As the air inside the camper dries out, you can begin to slowly reduce the inside temperature to your desired coolness. Remember that opening the door will let that hot humid air back in so keep an eye on the door.
Low campground voltage can also effect air conditioner efficiency. That can increase the current demand and cause the compressor to overheat and trip the thermal circuit protection in the motor. It wont start again till the motor cools off. Ice buildup from trying to run the AC full blast on a hot camper can also cause overheating. Both of these can reduce the life expectancy of your AC.
Reduce the "Heat Load" on the air conditioner.
Buy a roll (or two) of Reflectix at the Home Store. The material comes in 24 inch wide rolls, so measure your windows. Remember it can be taped together with box tape to there is very little waste and you can make a big panel for a picture window.
https://www.amazon.com/REFLECTIX-BP2...ords=reflectix
Cut it to fit your windows to reflect the solar load by reflecting the sun's rays. Keep the door closed as much as possible and cook outside.
White campers and roofs work best to reflect the incoming heat. Brown and Black campers may need additional air conditioners due to solar heat absorption.
I hope that helps you.
Herk
