Old 08-04-2016, 11:32 AM   #11
Georgia Frog Rally 2017
aceinspp's Avatar
Originally Posted by richp View Post
Hi,
If you havent already, you might want to check to be sure all other 120 volt devices are off -- killing them at the breaker if necessary. It's possible that the electric element in the water heater, your converter, and/or some other 120 volt devices are putting you over the top.
If the AC is totally isolated and still won't run, I'd be looking at whether your two generators are correctly paralleled, and if both are putting out good current at the prescribed level.
FWIW.
Rich Phillips
X 2 Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
Old 08-04-2016, 11:46 AM   #12
I have to agree.
If hooked up properly to two generators in parallel, you shouldn't have a problem getting ONE of the A/C units to run.
I'd be checking to be sure the output of the generators is what it is supposed to be.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 08-04-2016, 12:39 PM   #13
Havasu Bill's Avatar
My twin Honda 2000's work my AC fine when plugged into the 30A plug on the generator. The AC does suck the fuel and continuously filling the one gal tanks is a royal pain. I came across this on the forum and it works great! I now have 8 gal instead of just 2
Honda EU2000I Generator Dual Extended Run 6 Gallon Ultra Fuel Tank System | eBay
Bill
2016 Forest River 3250 Cardinal
2016 RAM 2500 Longhorn
Previously: 36' Country Coach
Havasu Bill is offline   Reply With Quote
Old 08-04-2016, 12:54 PM   #14
Originally Posted by NMWildcat View Post
I was just looking at the newer Hondas and looks like the companion generator has an RV 30amp plug built in that works with the parallel cables. I learn something every other day
Yep. I actually bought 2 "companions"
That way when it's cool and not running any ac I can use either one.
I give up a 12volt output, but I never use that anyways.
Twisted1 is offline   Reply With Quote
Old 08-04-2016, 01:10 PM   #15
dodosmike's Avatar
I have a eu3000 and it runs my AC in my 272BH no problem. Likely wouldn't run the microwave at the same time though. Never tried it to be honest.
My 30a power cord doesn't attach directly to the inverter. I made up a plug/box/cord to make it work. Been using it like that for a few summers now, but only when "rippin hot out", lol Likely this weekend by the looks of it.
The output on the 3000 is 23.3a outlet.
Ill try to post a pic:
HA!......it worked, look at me go!
dodosmike is offline   Reply With Quote
Old 08-04-2016, 01:55 PM   #16
nodrawers's Avatar
I just finished 10 days camping in 100 degree weather in OK with this setup and had no problems. Ran in economy mode. All breakers off except AC. The AC is 5 year old 13.5K Coleman. Couldent even start it before installing the easy start.
Tom & Laura USAF Ret Smsgt
1995 2500 5.9 Cummins 5 sp 3.54 diff
2011 Coachman Catalina 22FB
Days Camped 2016 80
nodrawers is offline   Reply With Quote
Old 08-04-2016, 02:12 PM   #17
2 Honda EU2000s in parallel should be able to put out 26 amps continuously, with an even higher surge capacity. If the Hondas are running in ecoboost off, and their circuit breakers are not tripping, something else is wrong.
Do you have a power management system that will not allow a non grounded source to input shore power? One thing I learned about my Progressive Dynamics EMS is that when using my Honda gennys, I must connect the Honda negative and ground receptacle outputs for it to work. There is an easy way to make a receptacle plug in adapter that will make the Hondas appear "grounded" to the EMS.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 08-04-2016, 02:14 PM   #18
HONDAMAN174's Avatar
Dometic A/C - Honda EU2000's
Like others have said, check your parallel wires. There should be a L and R on the ends.
Will they power up when you run microwave?
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 08-04-2016, 02:26 PM   #19
Dometic A/C and Generator
We had just gotten back from our 2 week plus trip and our daughter wanted to stay the last week she'd be visiting in the trailer since it had been so fun for her and our 2 grand daughters, so we thought the (OLD) 4200 watt generator we have had for years would be powerful enough to run the A/C since we got back just in time for the heatwave to hit for the week and over 100 inside the trailer by the afternoon was too much.
Got the generator going and no way!! When the A/C compressor kicked in the volts went down to less than 90 so I shut it all down before damaging the A/C unit.
The next day we saw Camping World had the Campion Dual Fuel 7500 generator on sale online and the local (2 hours away) Camping World honored the Internet price so out the door was just under $1,000.00.
The Camping World version has the 30 amp and 50 amp direct plug ins so no adapters needed, and it had some good reviews so knowing my wife and I would be needing a more powerful unit later anyway, we bought it.
Got it back home and except for the noise, 74 Db like the add says??? Try 91 Db on the plug side and 104 Db on the exhaust side, and yes that's about 5 feet from it but you still can hear it running all over the property, 5 acres, so it is NOT as quiet as was said!
But, it runs the trailer with no difficulty so we're happy we bought it. I love the hour meter that's standard, it shows running voltage and running Hertz also on the display.
We already have a Honda EU2000 also and could have spent another $1,000 plus for another one of those and the jumper cables to make them in series, or spent the $3,000.00 plus for the big Honda, however, although louder than we wish it was, the Champion, was a generator worth buying for us. Now problem solved for now and for boondocking later.
Tdbrn is offline   Reply With Quote
Old 08-04-2016, 03:03 PM   #20
Originally Posted by swbouton View Post
Hi all. Thanks for your replies. I am using them in parallel with ECO mode off.
make sure your Frig is on Propane and your Water heater is not set to electric. It also helps to make sure nothing that uses alot of power is kicked on. Think Coffee Maker, portable Ice maker, curling iron, or hair dryer
2015 Ram 2500 4x4 6.4l with 2015 Flagstaff 21FBRS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
dometic
