Old 09-29-2013, 04:16 PM   #1
Dometic A/C issues
Ok all I need some help. I am new to the whole forum thing so please excuse me if I do something wrong. I have a Dometic 13500 BTU ducted system in my 2 year old 26 foot camper. Last year the circuit board in the A/C fried on an electrical spike. It was replace as well as the thermostat and everything has worked fine until three weeks ago. Now when i turn the system on the blower comes on and approx. 30 seconds later the compressor turns on. It starts cooling and runs for about 2 minutes with the compressor turning off and the blower continuing to run. the camper does not cool down until late at night. it as if the compressor is not running long enough. When it does cool down the system will turn off and on every three to 5 minutes all night. The next day the issues repeat. I am out of warranty and want to try and repair myself is possible. Has anyone else experienced this issue.
dperrilloux is offline   Reply With Quote
Old 09-29-2013, 04:51 PM   #2
jimh's Avatar
my first thought is low freon causing short cycle.
before i would get into that, i would try another thermostat.
there is also a temp sensor on the evap coil that could also be the problem. i would eliminate the wall thermostat first.
jimh is offline   Reply With Quote
Old 09-29-2013, 04:54 PM   #3
markb5900's Avatar
Agree with the above. I would try a new thermostat first.
Is your fan set to auto on your thermostat?
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 09-29-2013, 05:09 PM   #4
The thermostat is a single zone three option digital stat with Fan, cool and furnace options.
Old 09-29-2013, 05:10 PM   #5
markb5900's Avatar
On the fan option, does it say AU, or Hi or Lo?
Mark B
2017 GMC 3/4 Ton TV
Old 09-29-2013, 05:12 PM   #6
CLASS "A" Senior Member
cfsoistman's Avatar
Fan contiues to runs since the t-stat isn't satified. Compressor may be kicking off due to high head pressure. Dirty filter or dirty indoor evaporator coil. Could also be outdoor condensor coil on roof. Before replacing parts check these out. Unplug the camper before taking the top off the AC Unit. That's where I would start.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 09-29-2013, 05:19 PM   #7
It gives me all options through the temp up down buttons.
Old 09-29-2013, 05:23 PM   #8
Thanks for the options but I have completed all of the above. Everything is clean. I am really leaning toward the sensor in the evaporator. The evaporator is clean but not getting cold. I guess it could be the compressor but seems to be electrical.
Old 09-29-2013, 05:28 PM   #9
markb5900's Avatar
As it should, just wondered what you had it set on.
Do believe it is is something in the compressor/evaporator. But wanted to make sure it was in auto and not hi or lo as the reason the fan kept running.
Mark B
2017 GMC 3/4 Ton TV
Old 09-29-2013, 05:31 PM   #10
It is on Auto.
dometic
