Originally Posted by EricS88
Hello all new member looking for some help. I have a 2009 Keystone Sprinter SS with a dometic 13,500 btu ac unit that i am having issues with. Last year it quit working on me when i took it out last and didn't get around to fixing it till this season. It was at the time blowing the 3 amp fuse up in the control module which completely disabled the use of my furnace or my ac. So i went and ordered a new control module for the unit and installed it this morning. Now I have a working furnace however when I flip the breaker to supply power for the a/c it instantly trips the breaker in the camper. almost as if I had a hot wire crossed on a ground. I don't even have the thermostat set to a/c when I turn the power on. This module I put in is not exactly the same as my original one as they no longer make it. I did however download a installation manual for it and made sure everything is installed as it should be from what I can tell. This unit is supposed to be a direct replacement. Is there anything else I should be looking at or that I'm missing that would cause the breaker to trip instantly? I'm wondering if I have a wiring problem up on the roof or a bad component of some sort? I have done some research before posting and everything I have seen is talking about the breaker tripping after 5 minutes of use or more. Mine is instant. Any help or guidance is greatly appreciated.
Get a helper. you need to be on the roof and at the t-stat at the same time.
Go up on the roof, remove the cover and remove the wires from the trailer to the AC contactor. The wires feeding the unit. While your there, spin the fan motor. Turn on the AC at the thermostat. If there is no trip the problem is in the unit. If the fan motor spun freely when you tried it then the problem is in the compressor.
Now hook up the supply wires to the contractor. Remove the wires to the compressor on the other side. Turn on the fan at the t-stat. See it runs. Turn it off. Now remove the fan wires from the load side and hook up the compressor wires. Turn it on. See what happens. This is how to troubleshoot. You must check each item individually.
