Old 09-20-2016, 05:48 PM   #1
Thumbs up Dometic A/C vibration
Hey guys, While new to this forum and New to RV full time. Not completely new to RV's
I bought this 2015 PUMA Unleashed 32TBS . While quite Happy with me deal. I have uncovered an annoyance in the A/C Model B59516
Seems the blower Motor asm has a major vibration going on.
Checked out the unit up above and determined that the squirrel cage blower portion is quite flimsy.
Went down and viewed a replacement blower piece and still the same wobbly setup.
My examination of the unit seems to come up with everything is clean and no debris.
Anyone encounter this?
Suggestions.
After all this was said and done. I went up to replace the blower unit. Something you will not find unless you pull the cooling blade off. And the only way o do hat I find is to remove the motor asm. What did I find. A huge MUD DOBBER home in the middle of the obscured part of the blades.
Well you know this causes an unbalance. However the damage was done to the shaft so complete ASM replaced anyhows.
Just wanted to share ...
Hawger is offline   Reply With Quote
dometic
