I took the first year free forever warranty then let it expire. The annual cost of a fairly cursive inspection was $300-$500 + parts. I figure if I put that in the bank, I can cover most expenses if needed. As for the AC, That is still covered by the Dometic warranty and can be repaired by any Dometic dealer. They did have some leaking issues and have extended the warranty so you should be covered there. If you do not get a favorable response from the dealer, call Dometic.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
