Dometic AC in 2014 Prime Time 315
I do not know if this is a problem or not but it sure seems strange.
My AC unit sometimes comes on but the compressor does not kick in. This morning I counted 6 times that the fan came on (it came on on high) ran for about 40 secs and then cut off for about 2 mins and then repeated the cycle. I finally got up after the 6th time and bumped the thermostat one degree down and the compressor came on and worked normally. The thermostat was set at 76 and a thermometer I have set above the thermostat read 75 so there was no need for anything to come on.
Later in the day as things warmed up to the 80s, everything worked normally.
Is there some reason the fan comes on and shuts off for no real reason. This has been happening since I purchased the unit in Oct 2013. The thermostat and a computer board in the AC unit have been replaced but this still happens. I am not familiar with an AC that runs the fan periodically like this but if it is normal, I guess ok.
2014 FR Crusader 315RST
2014 Ford XCabSD F250 6.7L
4x4 Lariat
