Dometic ac issue
My a/c unit in my 2015 freedom express 236bhs cools tt very good.the problem is that when it satisfies the thermostat,i.e. 72 degrees,it will not come back on when the temp goes up.I can turn it off at thermostat,then back on, then it will resume cooling.I did this twice the other night,then later on it would cycle as it should.The unit has a single zone digital thermostat which I replaced.Unit still does same.The outside temp and humidity have been very high. My dealer service manager said to move the sensor wire inside unit,however,I can find no sensor wire other than the freeze sensor wire on the evaporator core which seems to be in the proper location. I have researched all over the forums and Internet figuring that this has been addressed before,but have found nothing.I have called Dometic service but have only been told to take it to dealer.Dealer says they can take tt in sept and it will take at least several weeks to get warranty auth from Dometic. I am not impressed with this choice since they probably will not try hard to duplicate symptom.
