Old 04-18-2015, 01:54 PM   #1
Dometic AC Not Cooling
We have a 2014 Forest River Surveyor Cadet, bought new in August 2014, with a Dometic AC. Only used the camper 3 since August. This past weekend finally got to go camping, when setting up we had the thermostat set for 68 and the outside temp was 83, it ran for over an hour and only dropped the inside temp to 78 degrees, it does not seem to be cooling. Everything seems to be functioning fine. Any suggestions would be appreciated.
ftroop82 is offline   Reply With Quote
Old 04-18-2015, 01:59 PM   #2
captnrick3's Avatar
Since it's less than a year old, I would take back to the dealer (or a dealer) to check for proper coolant charge. That does seem pretty feeble if the outside temp is only 83. Should still be under warrantee.
2015 Legacy 340KP
2012 Wrangler Sport
captnrick3 is offline   Reply With Quote
Old 04-18-2015, 02:40 PM   #3
Crockett's Avatar
make sure:
1. water heater 110 is switched off.
2. adequate extension cord if used.
3. ducting is adequate.
it you just are getting set up, and the door is opened and closed alot, youll take longer to cool. youll also keep introducing humidity to the coach that the AC will have to pull before cooling the air in the coach.
Crockett is offline   Reply With Quote
Old 04-18-2015, 02:42 PM   #4
TURBS's Avatar
Is the quick cool dump open?
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-18-2015, 03:24 PM   #5
Quick cool dump is open
Old 04-19-2015, 01:16 PM   #6
bryanteddie0924's Avatar
Have a 2014 Wildcat. Had to have the A/C replaced because it kept freezing up. Took it out after replacement and did not cool, just kept running. Took back to repair shop- they had mixed up 2 of the lines. Take yours back and have it check while under warranty.
Eddie Bryant
Camping days 2015-16 so far
On a 7 week trip.
bryanteddie0924 is offline   Reply With Quote
Old 04-19-2015, 03:44 PM   #7
Reset A C
Unplug ac power and battery power at same time. On some brands will reset a c.
butchlochala is offline   Reply With Quote
Old 04-19-2015, 03:53 PM   #8
This is my first ducted system, can you explain the purpose of the "quick dump"? I wasn't sure why it was there. Do you get more total air flow using it? Or is it meant to cool the living space faster?
Mine does get much louder with the dump open.
tragusa3 is offline   Reply With Quote
Old 04-19-2015, 04:09 PM   #9
Stormrider151's Avatar
I believe it is used to bring the temp inside the coach down quicker than using the ducting. Then once the coach has cooled you switch over to the ducting to maintain the temp. That's what I do anyway. Works well.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 04-19-2015, 04:15 PM   #10
Thanks, I've been on a youtube search, and this guy said the same.
2013 F150, EBoost,4x4,CC, MaxTow
2015 Surveyor 245BHS
dometic
