Old 07-11-2016, 12:09 PM   #21
lgray's Avatar
Originally Posted by TURBS View Post
15k btu a/c takes closer to 2500 watts to start and about 1800 to run.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
Not according to this:
https://www.steadypower.com/pages.php?pageid=133
lgray is offline   Reply With Quote
Old 07-11-2016, 12:16 PM   #22
TURBS's Avatar
Dometic AC on Generator
Originally Posted by lgray View Post
According to my meter I draw 18-19 amps at start up and 15-16 running which is no where near 3500 watts.
Out of 4 dometic a/c units I've never had one draw over 20 amps.
I do see however dometic has recently changed the specs for a 15k to 3500k it used to be 2500k
Possibly because of the brisk air II
2015 Columbus 320RS
2008 2500HD Duramax
Old 07-11-2016, 12:22 PM   #23
TURBS's Avatar
My 13.5k runs almost exactly 1 amp less on start up and running then my 15k
2015 Columbus 320RS
2008 2500HD Duramax
Old 07-11-2016, 12:23 PM   #24
lgray's Avatar
A 15,000 btu, AC takes between 3300-3500 at start and 1300-1800W to run.
Jaqspe,
Regardless of the EXACT start wattage, the AC is likely putting a higher load on your generator than your microwave.
Old 07-11-2016, 03:36 PM   #25
Thank you for all your help. I have more information now. I put some cleaner in the gas tank that was recommended by Onan with no help. I tried to run the AC again, and this time I noticed a clicking noise coming from behind the fuse panel. It sounds like a turning signal. What can that be? Can that be the issue that I am having?
Jagspe is offline   Reply With Quote
Old 07-11-2016, 03:41 PM   #26
TURBS's Avatar
Transfer switch?
2015 Columbus 320RS
2008 2500HD Duramax
Old 07-11-2016, 03:56 PM   #27
Does the clicking mean something is wrong with it?
Old 07-11-2016, 03:59 PM   #28
Please post the make, model, and serial number of the generator.
If the transfer switch is clicking, then the delay switch on the control board of the transfer switch has been disabled.
BBQGUY is offline   Reply With Quote
Old 07-11-2016, 04:04 PM   #29
I wonder if your fuel pump isn't going out like I believe mine is (also have an Onan 4kw). I'm taking mine in tomorrow to get it checked out. It behaved similar to yours, at high altitude and hot. I used to hear a ticking sound during priming, but from what I understand, it should be more of a thud sound. Mine will run fine right now and run the AC, but I'm guessing it'll shut down again if I start driving and its 100F out. I also have to prime it 3 times or so before it'll start. Hence I'm leaning towards a bad fuel pump. We'll find out tomorrow and I'll keep you posted.
KansasFR3 is offline   Reply With Quote
Old 07-11-2016, 04:08 PM   #30
It is a Onan RV RV QG 4000.
Model Number: 4KYFA26100L
Serial Number: E120336370
dometic, generator
