Old 07-29-2014, 04:51 PM   #1
RudysWorld's Avatar
Dometic ac problem
Pulled into site today and rear ac works but front does not. Ran front with generator during lunch but now doesn't work. It does not have a electronic thermostat. The furnace fan will run but the ac fan will not run, furnace is on the same thermostat as the front ac. When i slide the switch to the on position I can hear a click but nothing else happens. Any ideas appreciated!!
Rudy - 10 year old long haired dachshund, RIP
2011 Georgetown 350TS
2013 Chevrolet Equinox toad
RudysWorld is offline   Reply With Quote
Old 07-29-2014, 07:07 PM   #2
H2oski
Are you plugged into 50 amp? Have you checked the circuit breaker? Maybe someone else will jump in here. Good Luck
Wife
2007 Chevy 2500 HD 6.6
2012 Sabre 31RETS
(LA) Lower Alabama
h20ski is offline   Reply With Quote
Old 07-29-2014, 08:33 PM   #3
RudysWorld's Avatar
Yes plugged in to 50, checked breaker. Checked fuse in ac unit everything ok
Old 07-29-2014, 09:06 PM   #4
TURBS's Avatar
Did you check the voltage at the power pole to make sure it was good?
Have you tried it back on gennie power?
"sabre owners united!"
turbs
Old 07-29-2014, 09:24 PM   #5
RudysWorld's Avatar
Not all of the 120 outlets have power. I think I only have one leg of 30 amp working. I will check with office in the morning. Thanks
Old 07-29-2014, 09:28 PM   #6
TURBS's Avatar
I think you have a bad leg of power.
This would be a great time to consider an ems hardwired surge guard.
Then u know exactly what power u have when u plug in and if for some reason theres a problem the ems wont let power in your trailer.
turbs
Old 07-29-2014, 09:57 PM   #7
dtomstant's Avatar
I agree..A or B side of power supply bad. Highly recommend in-line (behind cb panel) Surge Guard plus digital monitor as does previous member. Good insurance plus you always know your load distribution.
dtomstant is offline   Reply With Quote
Old 07-30-2014, 09:11 AM   #8
RudysWorld's Avatar
Moved to New site, lake front, and everything seems to work great. Thanks again for all your help!!!
Old 07-30-2014, 09:26 AM   #9
TURBS's Avatar
Sweet!
turbs
dometic
