Old 08-29-2015, 09:55 AM   #1
R3Jones's Avatar
Dometic Brisk Air II Heat Strip Add
I'm exploring options. I'm considering adding heat strips to my two ACs.
The main AC is a 15.5k ducted model controlled by a thermostat similar to the white one shown below. This main thermostat also controls the furnace. Would I need to install a thermostat, similar to the black one shown below, in order to control the furnace separately from the heat strip? Can I utilize the existing thermostat if I want the heat strip to run simultaneously with the furnace?
The garage AC is a 13.5k non-ducted model controlled by a thermostat similar to the white one shown below. Can I utilize the existing thermostat and wire the heat strip contacts to the wall thermostat's furnace contacts? The garage thermostat does not control the furnace.
Thanks for the help.
Name:	ImageUploadedByForest River Forums1440859978.975538.jpg
ID:	87223Click image for larger version
Name:	ImageUploadedByForest River Forums1440859990.192942.jpg
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
2017 2500 Denali Duramax
R3Jones is offline   Reply With Quote
Old 08-29-2015, 10:24 AM   #2
Sc00ter's Avatar
You would have to replace at least one thermostat for sure. Don't see a reason why you couldn't replace both as they seem to be independent.
We installed the strip in ours. You will need to buy the strip itself which goes in from up top and the thermostat which will come with a new brain box (both installed from below). Make sure you get the thermostat/box for the heat strip as I have seen a third set up for "heat pump".
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is offline   Reply With Quote
Old 08-29-2015, 10:39 AM   #3
Sc00ter's Avatar
After rereading your post, let me give a more accurate answer.
"Would I need to install a thermostat, similar to the black one shown below, in order to control the furnace separately from the heat strip?"
Yes to control the heat strip you would need a new thermostat, potentially for both ac units if you want strips in both of them.
"Can I utilize the existing thermostat if I want the heat strip to run simultaneously with the furnace?"
No, one thermostat runs the whole system (one ac and one furnace). Will get into the wiring in a minute.
"The garage AC is a 13.5k non-ducted model controlled by a thermostat similar to the white one shown below. Can I utilize the existing thermostat and wire the heat strip contacts to the wall thermostat's furnace contacts?"
No the heatstrip utilizes a special plug into the brain box and cannot be tied into the furnace output.
2015 puma 295bhss
Old 08-29-2015, 10:54 AM   #4
Sc00ter's Avatar
For reference on the wiring... Most importantly, disconnect all power 110vac and 12vdc before starting.
The actual strip goes inside the rooftop unit. You have to remove the cover (4 screws IIRC) and remove the styrofoam insulator. The strip simply slides in and attaches with included screws into predrilled holes. Rather easy. Dangle the strips power cord down through the roof opening and reassemble the foam and ac unit cover.
Inside the rv remove the filter cover and you will see your strip power cable dangling and the old brain box (I am sure it has a better name but that is what I will call it). There will be four sets of wires going into it. A normal three strand 110 wire (hot, neutral, and ground) attached by wire nuts, a squarish cannon plug that is the connection to the rooftop unit, a plug that looks like a phone jack which is the thermostat connection, and a small gauge two wire lead going to the furnace. The two furnace wires are low voltage and trigger the furnace (it will have its own 12v wiring going to it). The new box will have a fifth plug in for the heatstrip. The plugs are all different shapes so it is pretty idiot proof. Word of caution, the old brain box was plastic and held in place by a half threaded wood screw. The new box is made of sheet metal and I replaced the goofy (overly long) wood screw with a short sheet metal screw utilizing the same predrilled attachment holes. That screw somehow came into contact exactly with the hot 110v input and shorted out the minute I put power to it. I removed the screws and used double sided 3m automotive trim tape to secure the brain box to the ac unit.
The thermostat is wired in with three small set screws. Take a picture with a smartphone so you don't forget which color wire goes to which screw.
Hth. Minus the Sparks and removal of offending screws, the install took less than an hour. If you choose to put strips in both ac units, you will need two new thermostats with two new brain boxes. If you have any more questions let me know.
Scooter
2015 puma 295bhss
Old 08-29-2015, 11:07 AM   #5
bubbles's Avatar
We have heat strips in both our AC's and as for us the heat strips do not perform satisfactorily. They're a long time running before any semblance of heat is felt and they never supply enough heat to make a difference. We do not use the heat strip mode. Our fireplace does a commendable job when heat is needed and don't want to run the furnaces. A heat strip is not a heat pump and there is a huge difference in performance. If you make the install hope you will not be disappointed.
Old 08-29-2015, 11:08 AM   #6
R3Jones's Avatar
Very informative. Thank you very much!
I'll start my search now for the best price and actual part numbers and post an update.
Do you know if the heat strip part is universal to each AC size (13.5 and 15.5)? Or would there be different heat strip types for the units?
Thanks again for the help.
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
Old 08-29-2015, 01:58 PM   #7
Sc00ter's Avatar
Bubbles did you leave the heat on long enough? We are only talking about 1500 watts of heat with a massive amount of air being blown through. The heat is slow but will heat the coach. We never use the actual furnace unless temps get below freezing. Even then our furnace only kicks in at the coldest when the strip can't keep up.
R3 I think the parts are serialized for the individual units (size). The 15.5k btu is probably different than the 13.5k unit. I googled the actual part number (found on the ac unit) with the words heat strip to find the parts. Think I got the thermostat from amazon and the strip from another supplier. I know the ac part number is on the roof unit, but it might also be inside the filter cover inside the rv saving a hike on the roof.
2015 puma 295bhss
Old 08-29-2015, 02:01 PM   #8
Sc00ter's Avatar
This is the original post I stumbled on where another member z3406 had gone through this legwork. His posts were instrumental in getting mine up and running.
http://www.forestriverforums.com/for...all-65624.html
2015 puma 295bhss
Old 08-29-2015, 02:11 PM   #9
I also have a recently purchased Nitro 31 FQSL. Is your garage a/c factory installed? If so how do you deal with running both units on 30 amps. We have found that on hot and humid days our 15k unit just can't keep us cool and I am looking for options. Thanks for the help.
Tireguy397 is offline   Reply With Quote
Old 08-29-2015, 07:21 PM   #10
R3Jones's Avatar
Thanks for the info. I live in Florida so the winters are very mild. I believe the heat strips will keep temps up without using furnace most of the time.
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
Old 08-29-2015, 07:30 PM   #11
R3Jones's Avatar
The FR guys went out of their way to build a trailer for me. I had the factory install a 50 amp service, 2nd AC, power control center, and a 5500 Onan. That being said, utilizing the power control center, I have no problems running both ACs, water heater, and anything else on a 30 amp service. Usually the power control center kicks off the electric water heater for a couple seconds when the second AC kicks in. After it gets up and running the WH kicks back in. Here's a pic of the power control center aka power management system. Click image for larger version
Name:	ImageUploadedByForest River Forums1440894485.797398.jpg
-R.Jones
Nitro 31FQSL
RJones
2016 Nitro 31FQSL
Old 08-29-2015, 10:32 PM   #12
Sc00ter's Avatar
-R.Jones
Nitro 31FQSL
We live in Colorado and went through 40# of lp in our first two trips without the heatstrip. After that install, the furnace hasn't been used since. In FL, your furnace should never be needed again.
2015 puma 295bhss
Old 08-30-2015, 03:53 PM   #13
That is a sweet set up. I wish I had known about it before. Thanks again for the info
dometic
