Dometic brisk ii failure #2
My Forrest River Artic Wolf 5er had a Brisk II 15,000 from the factory and I added upon purchase a Penguin 13,500 Dometic in the bedroom up front. Used the RV 3 times in 2018 and the Rear unit took a dump in September of 2018. Compressor running/filters clean/ducts clear/ just no "COOL AIR" The return lines were hot as hell and Compressor was very hot to the touch. Seems Dometic has issues with this unit. Now to 2019 and after the 4th use this past weekend and two freeze up sessions, again the unit will not cool. The freeze sensor is in, everything is 100 percent so I would like anyone that has had issues in the last two years to pipe in with any info you have on these units. It might be time for me to consider a different brand all together. My mobile RV Tech says it is a loss of Freon on the sealed unit. MADE IN CHINA!!! Just like the Castle Rock Tires I took off on the way home from the dealer. This is BS
