Old 05-23-2012, 09:26 PM   #1
Dometic check light
Tonight I went to start the fridge for this weekend and the check light will not turn off. Stays on no matter if on auto our gas. Lit the stove to purge gas lines and same thing. Fuses all checked good. Any suggestions
2006 Rockwood 8280ss
biggie is offline   Reply With Quote
Old 05-23-2012, 09:43 PM   #2
VinceU's Avatar
I would first open both AC and DC power supplies with breakers/fuses. Restablish DC power first and and before restart on gas again check if check light is on steady. If it is, may be failure of logic board in back of fridge.
Old 05-23-2012, 10:39 PM   #3
Disconnected both ac and dc and retried and check light comes on right away for both again
Old 05-23-2012, 10:43 PM   #4
Herk7769's Avatar
Here is a pretty good troubleshooting guide.
After opening the AC breaker and pulling the fuse that powers the DC control board and turn OFF the propane.
Check the DC fuse with a multimeter and if good (it should be) plug it back in.
Press the "ON" button and the "AUTO" light should come on.
The Check light should also be "ON".
Select the propane tank you want to feed from and SLOWLY (I do mean REAL slow) open the valve. It should take a good 15 seconds from "crack" to full on.
Light all three range burners on high. Make sure they are blue and tall.
If so,
The check light should have gone out.
If not, turn off the fridge and open the outside panel (careful - it might have a bee hive in it) and examine the burner flue for obstructions or bugs.
Turn it back on and check for gas flow (smell). If no gas flow; it could be the control board or solenoid valve.
Also does it cool on AC? This will have nothing to do with the check light, though; but it will let me know if the control board might be the problem.
Name:	913th 3rd Annual Picnic and Camper photos 033.jpg
ID:	14322   Click image for larger version
Name:	Camper Fridge 001.jpg
File Type: pdf Fridge Operation and Trouble shooting.pdf (94.4 KB, 852 views)
HAM CALLSIGN - KC3FFW
Old 05-23-2012, 10:49 PM   #5
I will have to try that guide tomorrow. The check light stays on even in auto with shore power
Old 05-23-2012, 10:55 PM   #6
Is it normal for check light to be on when hooked to 110 v. and in auto with gas turned off? Will it still cool using 110 V. even though check light is lit?
Old 05-23-2012, 11:23 PM   #7
My understanding is, check light on, failed on propane, if in auto mode, and AC power were removed. If on auto, and have AC power, should never see the check light. If it comes on, and you have propane to everything else, turn fridge off, wait 3 minutes, and the turn on. This will reset everything, and it will try again.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 05-24-2012, 12:51 AM   #8
On another note I am lows away by how well our dometic works - both on propane and ac... Freezer keeps stuff frozen even while towing on propane. Very impressed.
brookside is offline   Reply With Quote
Old 05-24-2012, 05:38 AM   #9
Another thing is the light inside fridge doesn't turn on when you open the door. I am not sure it did before this happened either sop could be bad bulb
Old 05-24-2012, 05:55 AM   #10
Herk7769's Avatar
This is a BIG clue.
You need 12 volts and a lot of it to run the fridge on Propane.
The interior light is 12 volts.
Do you know how to use a multimeter?
Find out if there is 12 volts available to the board, if so your "eyebrow" control board might be fried.
Replacement Eyebrows
Might be time to also invest in a good surge protector for your power cord.
led pad
