Did you check for popped AC breaker. From the outside, with cover removed. Is it plugged in? With voltmeter, is the outlet live? At 8 years of age, anything with a chassis ground, I'd remove, wire brush clean and reassemble and see where you're at from there. Luck!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
