Originally Posted by roylea44
Can anyone tell me how to adjust the temperature on the Dometic Model DM2652 refrigerator that I have in my 2010 Coachmen Mirada ? I have moved the little slide located on the fin but it still freezing drinks in the lower part.
You should be in Auto Mode and raise the number to 5 as this is the coldest. The thermostat probe shouldn't have to be moved at all.
See manual I have attached.
Why don't you please explain why you ask? Do you not know how to change the temp?
If it is not getting cold at #5 over a day you probably have to have it checked. I use gas and not electric initially as it cools things down quicker.
I turn mine on a day before I leave to cool down properly.
Also check to see if your cooling fan is working. It has an inline fuse that may be blown and this may be why it isn't cooling.
