Has anyone removed this fridge in a Flagstaff or Rockwood V-Nose?
Installation instructions say there should be "0" clearance on walls on the sides and rear. I would like to add a cooling fan along the lines of what TURBS has done, but, he has another type unit and trailer. I'm specifically interested in what I might face when I attempt this.
Presently, the unit sits beside the house and the little factory fan seems to run constantly. It is hot here! There is warm air coming out the roof vent and standard sheet paper almost holds over the cool air intake grill at the bottom. Toilet paper might not slip as it is lighter. More air flow is all I'm after and before ordering a mess of "stuff", I'd like to learn more about the compartment.
I have seen the thread showing how the top of the compartment might not allow good removal of hot air and could be modified.
Almost time for first inspection (license plates also) and this one has never been on the road yet due to wife being ill. Later this fall, I may delve into this when it's cooler.
OH! Fridge freezer never over 10 degrees and lower box floats around 28 to 45 degrees depending on inside and outside temp. Not unusual to have 104 degrees in the kitchen area mid day.
Thanks.
