I’ve got a Flagstaff 5th wheel that will not run off AC. It’ll just run on propane. The trailer is plugged in to shore power at my house. Where do I start? Not much of a problem this weekend cause we will be dry camping but I’d like to get it resolved.
I also had a problem with the fridge, microwave, and all 110vAC outlets not working, just one time. I found that a GFCI outlet in the bath had tripped and that ALL of the 110vAC in the rest of the TT was supplied from this one outlet. I reset the GFCI and all had been good since.
Checked GFCI (in bathroom) and was not tripped. Double checked the breaker and all was good. We’re dry camping this weekend so the fridge will be fine running on LP. I made an appointment to take it in on Tuesday. Fridge is currently cooling with an extension cord and I’ll switch to LP when we leave on Friday.
Be sure to reset breakers full off, then flipped on. See where else is without 120 v AC. Breakers might be marked, and marked wrong
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS NO MORE Tricked out 2017 Sandstorm 250 T.H.
